Looking for a NOS '69S clutch disc or a after market one that will work.
1962 356 Cab, show car, sold.
Registry #983
R Gruppe #741
John, although I havent tried it I recently read that you can shim the 69S pressure plate out and use a standard thickness clutch disc.
Thanks...I did that and it works OK, but if I can replace it with a new one and not shim it, I would rather do that.
Registry #983
R Gruppe #741
Another option is find a clutch rebuilder most cities have them and just get the disc re-lined. They will want the presure plate so that they can set the correct depth. I have had it done for some old italian cars that the clutches are obsolete with no problems.
Tony Proasi
52 split window coupe
I've been looking for this disc for some time now. Best bet is to have one relined to match the PP. I've seen two for sale in the past year but both had a PP included, boosting the price into the stratosphere.
-- Matt
Check out Unobtanium-Inc.com
New blog posts all the time!
I have one that I can spare. PM sent.
