I have four or five MFI fuel pumps that either dont work or leak. Is there anyone out there who does this for a reasonable cost?
1974 911"S" - Silver
10 sec 67 VW
Early "S" Registry #439
I wouldn't do it until you know what car they are going onto since the space cams vary by displacement. Gus at Pacific injection has done mine.
there is fuel injection corporation that is in merced (i think>?)
not cheap!
there may be other rebuilders- would be interested in hearing from others that have had theirs done
gus does not do electric pumps
Member #755
Conda Green 70 911S
70 black 914-6 3.2
70 911 "Speedster" project
"74 IROC" tribute Jade Green RSR
Fuel pumps, not injection pumps
10 sec 67 VW
I think that there is a company called Zimms that sells rebuilt units in exchange for core fuel pumps. When mine failed, I looked into them but they were not cheap. I bought one from the classifieds here that had probably come from them but had only been used for a few months after rebuilding before the owner switched to carbs. It works fine. The tricky part seems to be sealing the two housings together with the O-ring without leakage under pressure. My original unit's brushes wore the commutator into oblivion but I still have it. The pump section looks great.
65 356SC Dolphin Gray
66 912 Green
69 911E Tangerine
72 911T GP White
72 911T Aubergine
72 911T Lilac
72 911S Black (voodoo)
90 964C4 Black Targa
94 964C2 Black Coupe
08 GT3 Speed Yellow
