Thread: Weird Chain Tensioner
    Mar 2006
    Louisville KY
    Anybody have any info about this style solid tensioner?They seem to be well built.
    Tony
    Tony Proasi
    52 split window coupe
    Jul 2008
    near Ottawa, ON,canada
    tensioner
    hey there , they were used early as an aftermarket replacement for the failing regular tensioner, the one advantage they have is that they are pretty much bullet proof and used by racer , the problem is that they need to be adjusted regularly ,, i have a set found in my 914-6 engine , i used them when i did the adjustement of the cam , an installed 930 tensioner with safety collars to preserve the original look
    freez
    Sep 2006
    La Quinta
    Yep, had a set similar to those. They did wear out the sprockets very fast. When I did the last rebuild I replaced all the sprokets and them with the 930 type like Freez did.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  1. FS: Chain Tensioner Update Kit / Like New!
    By 914-6gt in forum For Sale: 911 Parts
    Last Post: 03-28-2014, 12:49 PM
  2. Chain tensioner kits???
    By LDunville in forum Technical Info
    Last Post: 05-17-2012, 08:44 AM
  3. replacing chain tensioner on 73 E
    By cmcfaul in forum Technical Info
    Last Post: 07-16-2009, 06:50 AM
  4. How to ID chain tensioner upgrade on 2.2?
    By ulrichd in forum Technical Info
    Last Post: 08-14-2007, 06:41 PM
  5. Chain tensioner update on a 71 2.2
    Last Post: 12-21-2006, 05:16 AM
