Thread: engine question
    Sep 2008
    Monza, Italy
    engine question
    Due they costs the same money to prepare properly, do you suggest a 2.3L short stroke or a 2.5L long stroke for FUNNY driving?
    thanks
    Andrea
    ps: i'd like to use a 215 mm alu 901 gearbox, not a 225mm mag 911 ...
    Registry Member #1414
    NOSGRUPPE
    Jan 2003
    UK
    What about a short-stroke 2.5 litre ?
    E.g 66mm x 90mm
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Senior Member boba's Avatar
    Jul 2006
    DFW
    Quote Originally Posted by andrea70 View Post
    For the most part the build cost, labor, should be very close. The cost variables will be for special parts and prep (machining).
    If you have like to like components cost will be comparable. For example if both builds are twin plug the cost would be similar. Twin plug vs single plug would be a premium.
    Comparable quality parts will be close in cost.
    Rare parts; like Hi Butterfly, slidevalve, twin plug dizzy, TI rods, 906 rockers, etc; will drive cost up very quickly.
    65 356SC Dolphin Gray
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    72 911S Black (voodoo)
    90 964C4 Black Targa
    94 964C2 Black Coupe
    08 GT3 Speed Yellow
  1. a '68 engine question
    By 911quest in forum Technical Info
    Last Post: 11-06-2009, 04:58 AM
  2. Engine # Question
    By matt911 in forum General Info
    Last Post: 07-17-2008, 10:36 PM
  3. Engine # and VIN# question
    By EuroSC in forum General Info
    Last Post: 06-18-2007, 06:23 PM
  4. So what is it ? (engine question)
    By John Fusco in forum Technical Info
    Last Post: 10-20-2004, 03:53 PM
  5. Engine nr. question
    By DannyK in forum General Info
    Last Post: 04-10-2004, 03:26 PM
