Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Obscure Parts Geek Trivia Question
    What front suspension part does a SWB 911 have in common with a Boxster?
    Struts- easy
    Quote Originally Posted by Flieger View Post
    Struts- easy
    Funny. . .WRONG!
    What EXACT part number can you find in the suspension of a 1964 911 that you also find in the suspension of a Boxster?
    Nov 2006
    S. F. Bay Area
    narrow the search...
    Is it a suspension component or an obscure piece of 900/999 harware??
    Brian (your friendly ex-counterman)
    Brian
    S Reg #1032
    is it a bolt?
    Glenn Stazak
    parts in common
    My guess is either the sway bar or drop link bushings
    Speedo
    registry# 1283
    Ok, Brian, it's a piece of 900 series hardware. . .
    Sway bar bushings?
    Sway bar bushings?
    Negative!
    Final clue. . . it performs a slightly different function in the SWB car than in the 911. . . but it's the same part number, which is a supercede from the SWB number.
    Torsion bar adjusting screw?
  1. More obscure parts trivia. . . .
    By 304065 in forum Technical Info
    Last Post: 03-07-2010, 05:45 AM
  2. S oil cooler .. trivia question
    By preS in forum Technical Info
    Last Post: 09-17-2009, 09:58 AM
  3. 72 air filter housing trivia question
    By robmog in forum General Info
    Last Post: 05-04-2009, 06:05 PM
  4. Chrome bezel trivia question
    Last Post: 03-08-2009, 07:47 AM
  5. Switch knob trivia question
    By Allen Henderson in forum General Info
    Last Post: 12-29-2006, 07:55 AM
