Results 1 to 2 of 2
Thread: FS 20-Bolt BBS Wheels (calling all you RSR and ST guys)
    For sale, (4) BBS wheels as removed from a '76 930 Turbo with factory spacers. These are early, 20-bolt, non-drop center race wheels. Very cool and very light.
    Fronts: 8x15" (133mm backspacing), with Yokohama A-008's 225/50-15 tires (note corrected width dimension 29 dec 09)
    Rears: 10x15" (143mm backspacing), with single Yokohama A-008, 285/40-15 tire (sorry, one is missing due to irreparable sidewall damage).
    Wheels are straight and true and in very good to excellent condition. Centers are painted white, and halves are polished aluminum (think Miami Vice 1984). Porsche center caps included. I don't recommend driving on the tires due to their age, although it's pretty cool to see the rubber and remember that 20 years ago this was the hot setup.
    These wheels would be great for an ST or RSR project. Halves and sealing rings are still available from BBS should you want to change offset, width, or diameter.
    I can disassemble tires and ship wheels separately if needed.
    $900 for the set.
    Cheers, Chris
    Wheels have been sold. Thanks!
  1. Replies: 0
    Last Post: 04-02-2013, 07:02 PM
  2. Calling Switzerland Feb 1st
    By uai in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 01-23-2013, 12:39 PM
  3. The Road is Calling.. new VDO
    By tennster in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 04-30-2011, 09:31 AM
  4. Fan Shroud Clamp, 2 bolt vs. 1 bolt, 2.4 liter engines
    By caproader in forum Technical Info
    Last Post: 12-15-2010, 04:22 PM
  5. FS: Autopower Roll Cage - bolt in, bolt together
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 06-17-2010, 01:01 PM
