Monday was a big day. installed the engine in my 71E. Still needs some plumbing, routing etc......but it is in there. I included a before pic, for contrast.
Regards,
al
Regards,
al
Al Kosmal
the X-faktory
Current projects; 69-911.5
76S rat bastard---off to Germany
1970 914-4...off to Wisconsin
73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
66 912 ...off to France
71E 9111200979 ( gone to Paris..then to Corsica)
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
Nice work! That's a great before and after comparison.
Peter Kane
'72 911S Targa
Al, I really hate to be a wet blanket after all your nice work, but I think you've installed your sound pad backwards, the foam side is what should be glued to the panel. The smooth black side is the "show" side. Happy new year anyway
All right Al!
Rich
1966 911 #303872
ES#1197
RG#478
Al Kosmal
the X-faktory
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
Either way,it will flame-up if there is an engine room fire and cause the most damage. My nine twelve had a back fire and the new engine sound pad burned up all the way!and burned up the engine room real good! Don`t know if there is another option to this sound deadning other than no soundeadning at all,Cliff
Al Kosmal
the X-faktory
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
This is a milestone....after 2 years....I drove it out of the garage and washed it. Still needs Brakes bled, clutch adjusted and numerous details, but......and it's a big butt...it's alive.
Regards,
al
PS excuse the crappy cell phone pix, but my camera bit the dust.
Al Kosmal
the X-faktory
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
Congrat's Al.
Lord knows how many of us have had the pain and pleasure of resurrecting an early 911. It is a gratifying experience in the end, but along the way, there is always a reality check or two. Break the motor in gently if its a fresh rebuild, and let the rings settle in. Then run it like a raped ape after the 1k break in period and valve adjustment...
PS Bleed the brakes first...
Congratulations Al!
Rich
1966 911 #303872
ES#1197
RG#478
