Thread: 12AN to front oil cooler why not when
    Dec 2006
    Las Cruces, New Mexico
    the internal oil tank feed line to filter console is 15mm, the factory thermostat line ID is 15mm and the ID of AN12 fitting is 15mm. Parts measured were pre 72. Various posts stress AN12 a no no go 16. What am I missing?
    Early 911S member #166
    People think that the smaller fittings are too restrictive... here are my findings...
    In my track car (77 with high comp 2.7 RS engine), i only has the trombone cooler at first. It was running way too hot - 2 or 3 hot laps and the gauge was reading 250+.
    I cut the trombone cooler and ran some lines up to a factory RX7 cooler. I did not modify the inlet or outlet fittings, nor did I remove the internal pressure relief valve inside the cooler.
    Here are the results (photos taken at the track after several hot laps):
    It worked fine and the whole setup cost less than $100. The temp gauge has not gone above the 9:00 mark since making this mod.
    I typed up a long winded reply with pics that has disappeared... I'm going to give you the quick version...
    There is a lot of misinformation out there about sizing for oil lines / oil coolers. The link to the Burd site shows my findings...
    http://forums.pelicanparts.com/porsc...dispelled.html
    Maybe this might answer your question
    Mark,
    Take a look at this info. It might answer your question:
    http://www.batinc.net/files/kits.pdf
    Marc
    Id like to know myself. Porsche used smaller hose for the scavenge circuit.
    And then take a look at this post on the Bird Site...
  1. WTB 72 only front oil cooler
    By BOYER73S in forum For Sale: 911 Parts
    Last Post: 05-29-2011, 04:07 AM
  2. Front oil cooler
    By rffitz in forum General Info
    Last Post: 08-28-2007, 05:36 PM
  3. 72 Front Cooler Help
    By rick2 in forum General Info
    Last Post: 06-28-2007, 12:02 PM
  4. Fs New Front Oil Line Mounting Bases For Front Cooler
    By execmalibu in forum For Sale: 911 Parts
    Last Post: 06-14-2007, 06:58 AM
