Thread: My 67S back from paint.
    Dec 2006
    Las Cruces, New Mexico
    Finally after years of sitting after finding in barn in mid 90's. I decided a year + ago to get it running and refurbed. A matching # Euro car that made it to the southwest very early in it's life very minimal rust, battery area, rear window's and one seat pan was all rust repair needed. Car was born light ivory and repainted same. It will be for most part stock appearing interior and exterior with exception of muffler, deep 6's and late model front suspension. Original engine and transaxle are pickled and a 2.5 SS, a JOS box with quaife will power her. There is a vidio on link of original engine start up after 15+ years, note the chain rattle . Pics are in no particular order.
    http://s138.photobucket.com/albums/q...sto/?start=all
    Early 911S member #166
    Jul 2004
    Sydney, Australia
    Great set of pictures, thanks Mark
    Very topical actually. I'm just in, pretty filthy, from a 3 hour session in the garage, continuing to strip down the inside of my tangerine T. I face a similar rear parcel shelf as you had ... though don't have the issue of the outside panel thankfully ! Gives me inspiration to continue !!
    Paul
    1969 ex-South African RHD Tangerine 911T . 1970 ex-Southern Californian LHD Conda 911T 1955 Series 1 86" Land Rover (original Australian CKD … very slowly re-building) 1987 W124 230e
    (long term paid up member)
    can i ask if you are going to the trouble of putting it back to the original color why would you not put everything back to original? I have been lurking on this board for awhile and it just seems to me most on this board keep their cars from reaching full value by not being at least period correct.
    Just wondering
    uh oh, hold on to something.
    Dec 2006
    Quote Originally Posted by rick@cbx.com View Post
    Just wondering
    Sure you can ask, you just did and welcome to the board. A good question and I can only speak for myself. I'm not interested at "reaching full value" I'm interested in MY vision of what I want the car to be which is a 98% + stock appearing 67S. MOST every thing IS being brought back to original, interior, exterior, trim, radio, seats etc. The parts changing I'm doing is the way I want it at this particular time in my life. I want to go faster quicker hence the 2.5 engine and JOS geared transaxle. I also want it to handle and stop better so bolt in later model front suspension with alloy S calipers and rears to match. That said if you checked the pic link you will note the original parts have ALL been saved not modified and in some instances rebuilt as time allows, note refurbed original calipers, new SWB correct Koni strut inserts, new ball joints etc. The original engine, transaxle and front suspension, oil tank etc. were all removed and stored intact, not so much as a piece of the original engine tin will be used. All the modifications I'm doing can be undone in a few weeks with the original parts if I later choose or someone else chooses because I'm pushing daisies. Another way to think about it is what if I ran the # match engine and blew it? I drive my cars and run them hard so a possibility and no "full value" in that condition.
  1. Back in a longhood and thrilled to be back!
    By wolfgang1 in forum General Info
    Last Post: 01-19-2014, 11:15 AM
  2. Replies: 6
    Last Post: 07-04-2013, 11:53 AM
  3. Engine Fiberglass Cover-to paint or not to paint?
    By Varooom in forum Technical Info
    Last Post: 03-28-2010, 05:44 PM
  4. 68 Softie Back from Paint
    By Microgator in forum General Info
    Last Post: 07-07-2008, 05:02 PM
  5. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
