Thread: Replacing Ignition Switch
    I plan to replace my ignition switch, and have a question.
    Do the two fasteners (10 o'clock and 4 o'clock positions in the picture) need to be removed in order to remove the switch? If yes, how is this done?
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    Yep, they sure do. Those are anti-theft breakaway screw heads so the bad guys couldn't easily remove the ignition switch to steal the car. Guess they never saw "The Fast and The Furious" I use a small flat chisel and small ball pein hammer to catch an edge and then get the screw turning. They're not usually very tight, shouldn't take much. You can buy new 'breakaway'
    screws, or just use a standard phillips head screw. The 'bad guys' really don't care
    Thank you Ed!
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Frank, I personally recommend drilling a hole in the center of those tamper proof break-away bolts and then utilize (hammer into the hole) an EZ out to remove them. We just completed a detailed article for Excellence magazine on this subject. Good luck, TCallas
    Tony Callas
    Bingo! Although, I tend to replace them with allens. Pick your poison.
    -Marco
    TLG Auto: Website
    Being quite the purist, I recommend that you retain the tamper proof break-away type bolts that Porsche originally installed.
    Tony Callas
  1. NOS '69 911 ignition switch
    By Frank Beck in forum For Sale: 911 Parts
    Last Post: 08-27-2011, 12:22 PM
  2. Replies: 0
    Last Post: 08-13-2011, 01:19 PM
  3. Ignition switch help
    By 210bhp in forum Technical Info
    Last Post: 06-13-2011, 04:39 PM
  4. WTB: 67 ignition switch with key
    By Anthony67_911s in forum For Sale: 911 Parts
    Last Post: 10-12-2007, 02:20 PM
  5. ignition switch ?
    By robmog in forum Technical Info
    Last Post: 09-16-2007, 05:59 PM
