Results 1 to 10 of 10
Thread: 69 Driver's Floor Board - What do I Have Here?
    Aug 2006
    Chicago area
    Help again guys... So I go in to replace my driver's floor board on my very early 69 as the one that is in there is a cobbled POS. This one was listed as a 69-73 LWB floor board and is in great shape. So I go to install it and the fit is not perfect. I jockey this thing around and I just can't get it to fit.
    The threaded piece in the floor pan is missing the hole in the floor board by about a 1/4" or so - and the board is as far up as the top brackets will allow. Then I push the clutch in and with the stop bar moved all the way to the top, I still can't push the clutch in (to what seems) all the way.
    So, I start thinking, what the hell...? Do I have the wrong floor board? I pull it out and lo and behold, it is not an exact match with the current one. The pedal holes an shaped just a little different, the portion on the lower left that protrudes on the pictured board is not on my current one (it is just a rounded corner), and the attach point is only a semicircular cutout with no supporting metal bracketry. The current board secures with a loose bracket.
    So what do I have here? Is it correct for 69-73? Maybe my very early MY build used a different floor board. Sorry for the long explaination, but I could use a little help.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Aug 2006
    Chicago area
    Photo of FB I am trying to put in.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Hi Scott,
    The only differences I know about in pedal boards per year is: Targa and Coupe are different, sporto and manual are different and obviously RHD to LHD.
    HTH
    Alan
    Aug 2006
    Chicago area
    Alan, thanks - that is what I thought. I checked my 71 and this FB is identical to that one. The one in my 69 is definitely different and this FB shown here is a close fit, but will not work. I have heard that the really early MY69's were a little different in some respects than later in the MY. I wonder if this is one of those occasions. I should post a photo of my crappy FB in the 69 for reference.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Quote Originally Posted by t6dpilot View Post
    Looks like a 914 piece. hehehehe.
    I can take a shot of mine tomorrow if it helps, should be close to yours. Well at least production date wise. Who knows.
    AV Winans
    R Gruppe#435
    Senior Member boba's Avatar
    Jul 2006
    DFW
    I will also get a photo of mine as we know the vin's are close.
    65 356SC Dolphin Gray
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    72 911S Black (voodoo)
    90 964C4 Black Targa
    94 964C2 Black Coupe
    08 GT3 Speed Yellow
    Aug 2006
    Chicago area
    I knew my two early 69 brothers would come to the rescue! Thank you Bob and Aaron.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Jul 2006
    DFW
    Scott,
    Let me know if you would like some other angles before I put the carpet and mats back.
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    08 GT3 Speed Yellow
    Aug 2006
    Chicago area
    Bob, awesome of you to do that for me - thank you! Yes, yes, yes, the early 69MY driver's FB is different - if only slightly. I wonder if all 69's are like that or if they changed later in the MY. Looks like I am back to square one. Now I need both FB's. Aircraft spruce plywood would do the trick, but the bend causes a problem.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Stoddards has the originals. Is that a moisture problem? Your going to delaminate if you don't fix it. I used wood glue and pressed it together worked well.
  1. Wood floor board
    By Braukuche in forum For Sale: 911 Parts
    Last Post: 10-20-2012, 12:53 PM
  2. WTB: OE pedal board and floor board for 65-68 cpe
    Last Post: 04-06-2012, 07:53 PM
  3. WTB: LWB Driver's Floor Mat
    By t6dpilot in forum For Sale: 911 Parts
    Last Post: 05-22-2011, 05:28 AM
  4. SWB Passenger Floor Board
    Last Post: 08-30-2010, 01:05 PM
  5. FS: OEM Wood Floor Board
    By John Straub in forum For Sale: 911 Parts
    Last Post: 11-09-2009, 07:34 PM
