Results 1 to 10 of 18
Thread: loom rebuild / build new
    Sep 2008
    Auckland , New Zealand
    Talking loom rebuild / build new
    i have an ST build on the go , the car was a std T Europe delivered so ran carbs not MFI. and we are going to be running MFI , twin plug etc..
    I need to either : have the entire loom rebuilt with parts removed due to the extra items not needed ( passenger battery, clock , rear screen de mister , sunroof...)
    or have a new loom built .
    So who does everyone recommend to do either option ? i believe there was a firm in Germany that did a great job matching the original but can't find them online.
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    DynoDave
    Dec 2004
    Highlands Ranch, CO
    Wire Loom / harness
    Check out Y N Z Yesterdays Parts. They are located in Redlands, CA. We have used them in the past for a new wiring harness on a Spyder restoration. Their website is www.ynzyestredaysparts.com and their phone # is (909) 798-1498. Hope this helps.
    Dave
    Member # 351
    Passenger battery- just remove the cable at the driver's side clamp.
    Clock- easy to tape off the power wire and leave it in the harness.
    Engine MFI harness- is basically independent of the chassis harness-- speed switch wires are contained in the engine compartment with the black/purple running forward to the tach, but that's the same as in a carb harness. Coldstart (will you use the factory coldstart for an ST, I sort of doubt it) likewise is between fusebox power (present in carbed car), coldstart relay, coldstart switch (either the 2,0 or later version- these have slightly different operating rules as detailed in CHECK MEASURE ADJUST).
    Twin plugs, well you need power wires for the second ignition system, I assume you are using a pair of BOSCH BHKZ/CDI - these can also take power from the rear fusebox.
    The neat thing is the wiring harnesses forward of the engine compartment were basically the same from carb to MFI, the factory didn't differentiate all that much if you look at them side by side.
    YNZ are awesome, I will probably use one of their harnesses in my concours 66, but man, $2500 for a harness is big dollars compared to a few hours of labor to clean, repair, replace old terminals with correct rubber-covered German brass ones (with correct factory crimp) and call it cool.
    Of course if your carb harness has chafing or short-circuit damage (MANY do, particularly behind the gauges in the dash where the unfused gauge illumination circuit shorts against the brown grounds or the body sheetmetal) then don't hesitate to replace. Or if this is a PERFECT restoration then of course, diagram out everything you want with twin CDI, etc., and then have YNZ make it custom. . .
    Good luck!
    Try Rhode Island Wiring Service for DIY supplies. I like YnZ, but turnaround is fairly long and, as has been said, they are expensive.
    Tom F.
    Long Beach, CA
    Sep 2008
    cheers for the details , i will look into ynz as $2500 is a small price to pay when the existing one could have unknown issues and could go up in flames.
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Nov 2008
    Finland
    Quote Originally Posted by advtracing View Post
    If small joking is allowed: to put it into perspective, I just paid 180$ for Mk1 Mini Cooper wiring loom. So I wouldn't call 2500$ exactly cheap.
    - Ville -
    1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
    Yes, I wouldn't put a used one in any car without literally inspecting every square inch and checking each circuit with an ohmmeter. A good weekend project.
    Senior Member boba's Avatar
    Jul 2006
    DFW
    For my build which had quite a few delete items we felt it made more sense to build a new wiring harness than to strip and remove the un-needed circuits from a 37 year old harness. We started with a "kit" from Painless Performance which included a new fuse block as I was not concerned about keeping the original style block or fuses. We then used a modern wrap to clean up the install. We did reuse the factory connectors.
    http://www.painlessperformance.com/
    One additional advantage of a new harness is the reduced weight.
    Here are a few photos of the build and install in progress.
    65 356SC Dolphin Gray
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    72 911S Black (voodoo)
    90 964C4 Black Targa
    94 964C2 Black Coupe
    08 GT3 Speed Yellow
    which kit did you use?
    __________
    Sean
    1971T restoration in progress http://911restorationmadness.blogspot.com/
    1982 PCA club racing #372 D-Stock
    Registry #1595
    Sep 2008
    Talking
    looks nice , but i'm going the period correct path.
    As for price for a new one , $2500 is not cheep but if you put 100k into a car and had a fire due to an electrical fault which could have been avoided for $2500 you would be be pretty pissed off.
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  1. FS: SWB wiring Loom – Complete
    By 68911+1 in forum For Sale: 911 Parts
    Last Post: 09-07-2014, 04:54 PM
  2. WTB 69S Needs Tach, Engine Loom, Oil Cooler
    By jonnyw in forum For Sale: 911 Parts
    Last Post: 03-20-2010, 04:25 PM
  3. wiring loom and headliner removal
    Last Post: 09-24-2008, 11:20 AM
  4. Build your own RSR
    By PJenkins in forum For Sale: 911 Parts
    Last Post: 04-02-2008, 10:08 PM
  5. Removing wire loom from the tunnel?
    By classic in forum Technical Info
    Last Post: 09-13-2006, 11:44 PM
