Found these in a barn with a lot of other stuff. Any ideas on what they are? What's the best way to clean them up? My diesel-purple parts cleaner is great for steel and Al, but Mg not so much.
Tru6 Restoration & Design
69S Targa, Velvet Green
73T Coupe, Gemini Blue
Early S Registry #1462
67S, but to be sure. Inside the piston you will find a number. You can look than number up in a chart that has been posted by Tom Butler.
Richard
Thank you Richard, I think I found Tom's chart. I cleaned the insides of two of them, only found a letter E.
Shaun
Should look like this if OEM Mahle 67-68S pistons
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Clone in Progress
thanks guys, a few pics. they all have the E (maybe a Mahle logo?) on the inside and -1 on the crown. Haven't gone through them thoroughly, one face is badly pitted and here's a broken skirt, but they might be usable to someone when what they are is nailed down. they are 80mm.
I think it's an aftermarket piston in an OEM cylinder. The skirt looks to be different. May be an Empi piston?
Richard
On the crown, well below the -1, there appears to be another letter. Perhaps an E or M. A better closeup may help define this. EMPI did make piston sets, so this is a possibility; does anyone have examples of the EMPI pistons?
Dave here you can see a set of Empi P&C.
RIchard
http://cgi.ebay.com/ebaymotors/Porsc...#ht_500wt_1182
Isn't that hard to see symbol on the crown the 'Mahle' mark?
andy
67S in pieces
EarlyS: 1358
[SIGPIC][/SIGPIC]
Here are pics of 2 of the pistons with best stamping on the crown.
