Thread: Green faced gauges in 73?
    Oct 2004
    Cambridge, MA
    Barn find box o' gauges, some are pretty nice and always liked the green faced gauge. Have 4 good gauges in this pic, would just need a speedometer. How much of a plug and play or nightmare would it be to put these in a 73?
    Tru6 Restoration & Design
    69S Targa, Velvet Green
    73T Coupe, Gemini Blue
    Early S Registry #1462
    HI Shaun,
    I'm not sure that you want to bother trying to install a 912 tach into a 911.
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    Hey Shaun,
    I'm also backdating my gauges to the green face style and right now I have an early speedo installed. It's plug and play.
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
    Senior Member mimimemegna's Avatar
    Nov 2007
    Sanremo Italy
    Hey Shaun
    no in 73 green gauges!
    Maurizio G.
    Early S Registry member #1253
    1968 MY 1969 Light Ivory 911E
    Nightmare. . . .
    tach will need conversion to work with 6-cylinders and whatever ignition you are using (it won't work even with Bosch CDI without an "intermediate unit" and even then the capacitor values are designed for 4-cylinder)
    early oil temperature gauge is different than LWB, sender has different resistance values and costs over $100-- you could use the lwb sender but then you will have to convert the gauge
    915 speedo drive is different than 901, you will have to figure out that also
    and look at those chrome rings, those gauges need to be properly restored to look and function correctly-- big dollars . . . might as well have the 73 gauges re-done to perfection if you're going to spend that kind of money $800
  1. FS SWB green faced gauges
    Last Post: 07-21-2012, 09:05 PM
  2. WTB: Green faced '65-'67 VDO gauges
    By flatsixcrazy in forum For Sale: 911 Parts
    Last Post: 07-05-2012, 04:50 PM
  3. Green Faced Instruments
    Last Post: 04-06-2010, 08:56 AM
  4. FS - green faced clock
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 06-07-2008, 02:55 PM
