Thread: 15" Wheels on standard fender
    Sorry, but I did a search and could not find what I was looking and I know someone has this information right at their fingertips.
    On a 1970 standard fender car (no alterations), what is the widest 15" wheel front and rear that can be mounted as well as the offset?
    Thanks in advance.
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    Apr 2003
    Portland, OR
    These charts may be helpful:
    from http://instant-g.com/Products/Wheels/WheelFit.htm:
    Wheel Fittment Chart
    Front Fittments:
    Wheel Offsets Max Tire Notes:
    911 Narrow 70-89
    7x15 10.8, 12.5, 23 225/50/15 Easy
    7x16 10.8 225/50/16 Tight 911 Offset
    7x16 23 225/50/16 Medium 951 Offset
    6x16 12.8 205/50/16 Tight 930 hubs on narrow body or 19mm spacer
    8x16 53 225/50/16 Easy 930 hubs on narrow body or 19mm spacer
    7.5x17 23 205/50/17 Easy
    7.5x17 23 225/50/17 Tight
    7.5x17 53 235/45/17 Easy 930 hubs on narrow body or 19mm spacer
    8.5x17 53 235/45/17 Easy 930 hubs on narrow body or 19mm spacer
    9x17 53 245/40/17 Medium 12.5-19mmmm spacer
    7.5x18 53 225/40/18 Tight 12.5-19mmmm spacer
    8x18 53 235/40/18 Tight 12.5-19mmmm spacer
    911 Wide 70-89
    8x15 10.8, 12.5 225/50/15 Easy 930 hub or 911 hub -w- 19mm spacer.
    7x16 12.5 225/50/16 Easy 930 hub or 911 hub -w- 19mm spacer.
    8x16 12.8, 23 245/45/16 Easy 930 hub or 911 hub -w- 19mm spacer.
    9x17 23 255/40/17 Easy 930 hub or 911 hub -w- 19mm spacer. 930 Rear
    10x17 23 275/40/17 Tight 930 hub or 911 hub -w- 19mm spacer.
    10x18 40 285/30/18 Tight 931 hub or 911 hub -w- 19mm spacer. 993TT Rear
    964 Narrow 89-94
    9x16 53 245/45/16 Very Tight
    7.5x17 53 225/45/17 Easy
    8.5x17 53 235/45/17 Tight
    9x17 60 235/45/17 Tight 1/4" Spacer
    993 All 95-98
    7x16 53 225/50/16 Easy 951F
    8x16 53 225/50/16 Easy C2/951 Rear
    9x16 70 245/45/16 TIght 993-16" rear
    7x17 53 225/45/17 Easy 993/C2 Cup
    8x17 53 235/45/17 Easy RSA Rear
    9x17 53 245/45/17 TIGHT 993/C2Cup Rear
    Rear Fittments:
    911 RS, S, Carrera
    7x15 12.5, 23 225/50/15 Tight Fuchs
    8x15 23 245/50/15 Tight 911/944 rear
    7x16 10.8/23 225/50/16 Easy Fuchs
    8x16 23 245/45/16 Easy Fuchs or 951 Rear Phone
    9x16 23 245/45/16 Easy Fuchs
    8x16 53 245/45/16 Easy Use 30mm 1"-1.25" Spacer 951 Late or C2
    9x16 70 245/45/16 Easy Use 50mm-2" Spacer 993 Rear
    9x17 23 275/40/17 TIGHT May use 255/40/17, depends on car Aftermarket C2/993 Knockoff
    9x17 53 275/40/17 Med Use 23mm Spacer Watch inner fender/Oil Lines
    10x17 23 275/40/17 Very Tight Aftermarket, Borbet/HRE etc.
    10x17 53 275/40/17 Depends on car Use 23mm-1" Spacer
    10x18 40 285/30/18 Very Tight No spacer to 1/4" 993TT wheel
    10x18 65 285/30/18 Very Tight 1.5-1.75" spacer
    911 Wide
    All up to 11 wide
    23mm or add spacers
    12x17 Easy 315/35/17
    12.5x17 Carefully! 335/35/17
    12x18 Carefully! 335/30/18
    964 Narrow 89-94
    8x16 53 245/45/16 Easy Stock wheel with upside tire
    9x16 70 245/45/16 Med 993 16" wheel
    9x17 53 255/50/17 Easy 965 / 993 Cup wheel
    9x17 53 275/40/17 Tight 965 / 993 Cup wheel
    10x17 53 275/40/17 TIGHT
    9x18 65 265/35/18 TIGHT 1/2" spacer needed to clear trailing arm Boxster wheel
    10x18 65 285/30/18 Good Luck 1/2" spacer needed to clear trailing arm 993 twist or sportclassic II
    993 All 95-98
    9x17 53 275/49 17 Note lots of space to the inside. 993 cup
    10x17 53 275/40/17
    9x18 50 265/35/18 Med Boxster SCII
    9x18 70 265/35/18 Easy Optional
    9x18 65 265/35/18 Easy
    10x18 65 285/30/18 Very Tight 285 is tight on 993, trick is to inset wheel. 993/996 fittment twist or SportClassic II
    http://members.rennlist.com/911pcars/WheelWts.html
    Harry
    Member #789
    2009 MB C300
    May 2005
    Oroville, CA
    The rear list is a little confusing. I think the narrow body cars were put in with the RS,SC and 3.2 Carreras.
    A 70 rear fender is very close (ie sometimes rubs) with a 7X15 (23) with 205/60 on it. I am refering to a stock car. 225/50s will fit if you have stiff race suspension with a lot of camber and rolled lips.
    We have been able to put a wider tire with a 8 that was made by widening a 7 on the inside. But not much bigger than a 225/50.
    The best fit is a 7R type offset with a 225/50 and 15mm spacer.
    IMHO
    And fronts have plenty of room for 7X15s (23).
    H
  1. WTB: seat "fins" for 1971 911T standard seats
    By ez e in forum For Sale: 911 Parts
    Last Post: 02-18-2014, 12:58 PM
  2. non-standard paint code "716"
    By Red Car in forum Technical Info
    Last Post: 02-13-2014, 05:56 PM
  3. Source for non standard idler wheels
    By parced@telia.co in forum Technical Info
    Last Post: 07-05-2009, 09:29 AM
