901/02 Case. Media tumbled, oil passages R&R'ed. Uprated oil relief. Machined for Carrera oil pump, and intermediate shaft bearings. Oil squirters installed. All critical dimensions and main bore standard.
Includes the following:
Rebuilt Carrera oil pump.
Intermediate shaft
Long stroke counter weighted crank, standard, rebuilt rods.
Resurfaced, non "S" flywheel.
Case through bolts.
Sand cast chain boxes.
930 chain tensioners.
two three bearing cam carriers.
Refinished rockers and shafts.
Yellow tag "S" distributor.
Have short stroke counter weighted crank as an alternative, Not checked.
All components clean, finish on cast parts restored to original.
Have set of core correct 67 "S" heads available, not included.
$4500 plus shipping, no pay pal
Respond at:
drkidneydr@aol.com
