Results 1 to 9 of 9
Thread: 69 vs 70+ gauge opening sizes?
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    I found a couple of threads to reference:
    http://www.early911sregistry.org/for...ighlight=gauge
    But no definitive answer - are the gauge hole openings on the 69 smaller than the 70+ cars? I am changing out the gauges in my 912 and want to know if I have to futz with the thumbscrews (honestly - how did they get those on in the first place?) or can I use the later rubber ring friction mount of the later cars? I suspect the dash holes are slightly larger in the later cars.
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    Hi,
    Gauge holes are smaller in pre 70 cars. Porsche started to use the wider socket fit rubbers for the 70 model year.
    HTH
    Alan
    912->911 conversion
    Nov 2004
    Thanks Alan!
    Keith Adams
    I had no idea. good info. this should be in the model yr. specific thread.
    thanks
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Quote Originally Posted by Alan.uk View Post
    Hi,
    HTH
    Alan
    You sure? I think the opposite. I have a '69 with late tach and speedo gauges. They wouldn't fit if the gauge opening was smaller. Up to '69, the gauges are retained with a U-shaped bracket with thumbscrews to secure in place. Later gauges use a rubber sleeve to provide a friction fit in the IP.
    Sherwood
    912->911 conversion
    Nov 2004
    Quote Originally Posted by 911pcars View Post
    Sherwood
    Sherwood - did you use the later gauges with the rubber sleeves, or with the U-brackets and thumbscrews?
    My question/problem is related to using 69 gauges and a 69 dash, but using the rubber rings to make it a little easier.
    Keith Adams
    Jan 2003
    UK
    The gauges are the same size - like for like - eg all '65-'89 speedos have the same casing diameter, etc.
    However, as Alan states, the holes in the dash are smaller for the versions held in via brkts on the rear of the gauges.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Quote Originally Posted by lkadams View Post
    Keith,
    The late rubber rings would make the OD of the gauge too large for the opening. I don't recall, but perhaps the early factory gauges were equipped with a thin rubber sleeve, maybe nothing at all. The factory parts illustrations should comfirm what was really there.
    Late gauges don't have threaded mounting posts on the back to use with a U-bracket.
    Sherwood
    SWB gauges have a thin rubber ring right next to the chrome ring.
  1. LWB Wheel Opening Trim ('69?)
    By mshaver51 in forum For Sale: 911 Parts
    Last Post: 04-10-2012, 07:52 AM
  2. '71 gas/oil tank gauge, early style gauge blanks, misc. parts
    By cosley in forum For Sale: 911 Parts
    Last Post: 11-26-2011, 05:25 AM
  3. Fan Sizes
    Last Post: 06-18-2010, 07:04 AM
  4. wtb: oil press/temp gauge & 914 gas gauge
    Last Post: 12-30-2007, 07:35 AM
  5. Gauge opening sizes
    By 911pcars in forum Technical Info
    Last Post: 10-06-2005, 06:55 AM
