Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: What are the best tires for a 911S '73
    Hi,
    I'm looking for advice/experience with tires for a '73 911S.
    I used to buy Yokohama A008s, but they are no longer available in the size I need (205/60-15). Is there any tire that you can recommend that comes close to the A008 in regards to performance characteristics ?
    Thanks much in advance
    I use Yokohama Advan A048s. How many miles do you need out of them? Street or track?
    Thanks for the recommendation - I'll check them out.
    I just need them for street driving - don't do track (yet).
    Cheers
    Conny
    Never mind
    The Advans will wear out while you are just thinking of driving.
    Wear rating is 60- yes- 60.
    They sure grip well in the dry, though.
    I am super happy with the Michelin XWX tires I put on my S. Great grip, no road noise and they look great. They are very expensive and given this the Vredestein tire is a better value for the money. They, too look reasonably period correct and have a good grip.
    RGruppe member 445
    Senior Member sweetE's Avatar
    Dec 2002
    Highlands Ranch, CO
    If you are just in need of a street tire you may want to check out the "BFG G-Force Sport" - they have it in the size you want
    Dale Thero S Registry # 200
    I changed up to 16" wheels due to the lack of good options for 15" wheels. When my car was new I used XWX's and CN36 (pirelli) and much preferred the CN36 which I think is also being reproduced now. The XWX was very good in the dry but was terrible in the wet. Very bad aquaplaning. The CN 36 was almost as good in the dry with more progressive breakaway and was, for the time, a very good in the wet.
    I am now running Bridgestone RE-11's on 16" wheels. They are very good in both wet and dry.
    Having a set of 16's is cheaper than buying reproduction XWX or cn 36's
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    There are some pretty good tires available in 195/65-15, which is closer to the original size, at very reasonable prices. I don't like the 205/50s or 205/60s on an early car, but many will disagree.
    Tom F.
    Long Beach, CA
    tires
    Quote Originally Posted by coma View Post
    Cheers
    Conny
    Conny,
    Check these out.
    http://www.tirerack.com/tires/tires....omCompare1=yes
    al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
  1. 1969 911S Targa Tires
    By George Klouda in forum Technical Info
    Last Post: 03-31-2024, 07:52 PM
  2. Tires for 1973 911S?
    By 78mochasc in forum Technical Info
    Last Post: 08-17-2016, 02:53 PM
  3. '71 Targa 911S tires
    By v71911S in forum Technical Info
    Last Post: 05-20-2007, 07:43 PM
  4. opinion for 911R/911S tires
    By 50/50 in forum Technical Info
    Last Post: 07-04-2006, 11:52 AM
  5. 911s size wheels and tires???
    By ml911rs in forum Technical Info
    Last Post: 01-14-2004, 12:14 PM
