Results 1 to 10 of 18
Thread: 67s heat and throttle lever both on parking
    Dec 2006
    Las Cruces, New Mexico
    hand brake assembly, also has heat control lever forward. PET indicates twin on hand brake 68 year forward. The stand alone forward lever controls heater box mixer's. I removed hand brake assembly that heater lever was controling nothing any input appreciated.
    Early 911S member #166
    Jul 2008
    near Ottawa, ON,canada
    68 brake assembley
    i have 2 68 , a very early and a mid year , and both have the single lever,
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    Hi Mark, not sure I understand your question, are you asking if the 67S had both heat and throttle levers? If so the answer is no, hand throttle didn't start until MFI cars in 69. Heat lever was forward on the shift console. I'm restoring my 67S right now. Can send you a picture of my assembly if you'd like.
    Dec 2006
    Sorry if not clear, I have a heat lever forward and seperate on the tunnel in front of hand brake that does function. I also have a throttle and heat lever on the hand brake assembly. After reading a old Excellence article on the 67 S Jenning's car where the writer stated he "lifted the hand throttle and pumped the gas pedal" it motivated me to replace the broken plastic piece that controls the throttle which used to function. I then noted in PET while looking up part # a 67 was supposed to have only a hand brake with heater control forward. Hope understandable now, a picture greatly appreciated.
    Oct 2008
    Burford, ON, Canada
    Mark, It sounds like you have a 69 or later hand-brake assembly with heater & throttle controls installed in your 1967. You would need to get the proper assembly.
    hand throttle didn't start until MFI cars in 69. .
    My `68 on carbs has the hand throttle sitting next to the handbreak lever, as it should be.
    Rgards, Mike.
    Dec 2008
    Woodland Hills, CA
    Quote Originally Posted by Mycar View Post
    Rgards, Mike.
    I also wondered about my 68 911. It only has the heat lever and no hand throttle lever. But, when looking at the original carbs and linkage, it appears that there is an extra throttle ball connect for that purpose that is not being utilized. So as others are, I am confused about this issue as well.
    Senior Member rgrimm's Avatar
    Jan 2006
    Fargo, ND
    My '68 normal has the heat and hand throttle lever. The hand throttle lever, however, is not original. I "modified" the car about 4 years after I bought it.
    Roger
    68 Sand Beige 911 Coupe #11830091
    84 Moss Green 911 Carrera
    Senior Member 72tii's Avatar
    Nov 2004
    Bedford, TX
    In '68 the hand throttle only came standard on the Sportomatic cars. My '68 Normal does not have it.
    1968 911 #11830241
    Early S Registry #810
    R Gruppe #461
    Oct 2009
    Indiana
    Friends,
    I am restoring a very early '68, and I would be very interested in seeing photos of a CORRECT hand brake assembly. My car came with the hand brake and two levers: throttle and heat.
    I'd really like to consolidate various separate threads into a single information resource for future restoration by enthusiasts. This community of enthusiasts has a tremendous amount of expertise, which I'd like very much to make more accessible to novices like me.
    Does anyone have a reference for the proper finishes on the various parts of the assembly?
    I'm going to initiate a separate thread for hand brake restoration, and it would be very nice if others would offer their expertise to the community at large.
  1. Manual Throttle Lever
    Last Post: 10-05-2012, 11:35 PM
  2. Pic of 73S throttle lever parts
    By merbesfield in forum Technical Info
    Last Post: 03-23-2011, 06:34 AM
  3. WTB: Hand Throttle Lever and Knob
    By RTincher in forum For Sale: 911 Parts
    Last Post: 10-08-2010, 10:43 AM
  4. 914/6 throttle lever mechanisim
    By Cliff in forum General Info
    Last Post: 07-02-2008, 08:53 PM
  5. Replies: 2
    Last Post: 12-16-2004, 01:59 PM
