Results 1 to 8 of 8
Thread: Front Hub Corrosion!
    Wow. I went to install front wheel bearings and found this. . . never seen corrosion like this before. Compare to a known good hub.
    Ordinarily I'd just bead-blast it off, but this is the machined mating surface for the disc, I can just imagine imbalance problems resulting from a surface that's not true. I suppose I could chuck these up in a lathe and make a truing cut (that's what the Factory did to machine them, look at the marks in the good hub). . . or just source a good set.
    Sooo, just how many years were those at the bottom of the Atlantic
    Ed, how did you know these hubs saw action in the battle of Jutland? They will make great paper clip holders once the studs are pressed out . . .
    May 2006
    CT
    I think I have a pair of SWB front hubs.
    PM me if you need a pair.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    That would throw your rotor off center in the caliper.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Semjon Semjon's Avatar
    Jun 2005
    Groningen, Netherlands
    They tend to corrode quite well....
    here are mine;
    They will be replaced...
    Early 911S registry member #1391
    Built '65, MY66 911 in total restoration
    That is a great image of the fatigue/stress cracking that we may all need to be aware of. I would expect if you were you test these with magnetic particle (magnaflux), there would be other cracks not visible to the naked eye. This is also a good reason not to chock them up in a lathe and re-use them.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Oct 2008
    Burford, ON, Canada
    These really suffer from heat and galvanic corrosion. I think it is a good time to stock a spare set for a rainy day.
  1. corrosion
    By Cliff in forum Technical Info
    Last Post: 12-04-2010, 08:32 AM
  2. Early 911 corrosion protection:
    By vintagemotion in forum Technical Info
    Last Post: 11-10-2009, 08:31 AM
  3. Battery Corrosion - Replacement??
    By jcarpio in forum Technical Info
    Last Post: 02-13-2007, 01:43 PM
  4. corrosion protection
    By John Fusco in forum General Info
    Last Post: 11-25-2004, 04:35 PM
  5. Corrosion Repair
    By heirplane in forum Technical Info
    Last Post: 02-12-2001, 04:09 PM
