Results 1 to 7 of 7
Thread: Fuses for 67
    old softie67S
    Feb 2007
    Sanibel Fl
    Fuses for 67
    A restoration shop broke my fuse block while detailing the front trunck area of my 67S. The fuse block has been replaced but he did not write down the fuse size/location. I have checked a wiring diagram but it does not specify the fuse size. Anyone have a reference or image that defines what size fuses to use?
    Tom
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    Fuses for 67
    Tom, shop manual doesn't show them either, but I'm sure the owners manual does, do you have it?
    old softie67S
    Feb 2007
    Sanibel Fl
    wish I did
    Ed
    I do not have an owners manual. Could someone check theirs?
    Tom
    60 356 Cab
    Sep 2008
    Portland, OR
    Tom,
    Per the owner's manual from my '67...
    "Fuses
    All fuses are 8/15 amps, except:
    Fuse #4 (wipers, screen washers) - 24/40 amps
    Fuse #3 (auxiliary heater) - 25/40 amps"
    Good luck!
    Patrick... Member #1707
    '58 356
    '67 911
    '69 911
    Jan 2007
    North of the GG Bridge
    Remember that the #1 fuse is at the front of the car and the #12 fuse is near the firewall or rear of the car.
    I can't remember who posted these. they are for 70 to 73 , but they might help.
    old softie67S
    Feb 2007
    Sanibel Fl
    thanks for the help
    Guys
    As always, your help is truly apprecieated.
    Thank you
    Tom
    Tom
    60 356 Cab
  1. Tool kit Pudenz fuses
    By peon77 in forum For Sale: 911 Parts
    Last Post: 10-27-2009, 10:58 AM
  2. 5 amp bullet fuses
    By kilodawg in forum Technical Info
    Last Post: 12-29-2007, 10:10 AM
  3. Running lights keep popping fuses.
    By joetiii in forum General Info
    Last Post: 04-01-2007, 04:29 PM
