Does anyone know where I might be able to get two power window switches with the chrome bezel? Thanks for your help.
George Mihalko
S Registry #1130
R-Gruppe #540
1973 911 S
1972 911 RS Replica
1960 Roadster
2006 S Cab
Stoddard has them new, I wouldn't trust used as the plastic tabs holding them together very often break, leaving a perfectly good switch useless. They are advertised as sunroof switches, but it is the exact same part, same part number, 901.613.621.00. If this link doesn't get you to the exact item, search by part number.
http://www.stoddard.com/shop/shopdis...asp?Search=Yes
Mike O'Meara
Reg #1043
72 911T
56,59 356s gone
67,68 912s gone
Bahia Red '72 911S
Meerblau PTS 2019 Speedster
ES #333
From Partsheaven...
http://cgi.ebay.com/ebaymotors/PORSC...Q5fAccessories
Peter Kane
'72 911S Targa
Just got off the phone with Paul at Stoddard's. He spent some time retrieving the chrome bezelled switches and took some measurements. Here is what we determined:
Dimensions in MM:
Original Switch:
Chrome Bezel: 29x41 Body that inserts into door panel: 19.5x32.3
Current Switch:
Chrome Bezel: 27x38 Body that inserts into door panel: 19x29
Most likely the current replacement switches will be too small to fit into the original cut-outs, but I ordered a couple to see for sure.
I'll let you know of my findings.
George Mihalko
S Registry #1130
R-Gruppe #540
1973 911 S
1972 911 RS Replica
1960 Roadster
2006 S Cab
Bought two in June of '95 and one in Jan '06 and all three fit and are on the car working perfectly, at $34.00 each as opposed to $197!! If there are some bad or ill-fitting switches out there, it is certainly important info to add to the collective info bank, but what I've gotten from Stoddard are exact part number as per parts book and exact look and function as originals. HTH
Mike O'Meara
Reg #1043
72 911T
56,59 356s gone
67,68 912s gone
Just in case it helps, the chromed surround switches are different (in appearance) from those used up to 71 and those for the 2.4 ie 72 and 73.
The sun roof switch is also different and also uses a different cable connectors.
HTH
Alan
PS I have pics of all these if it helps
Just went out and measured mine and they are all 27X38. The two others I have, one new and one in pieces, are the same size. So there are size issues, but if it helps, mine are installed in original '72 door panels with electric windows as original equipment, and they fit and more importantly, stay in place in the original cut-outs in the door panels. Also, obviously, the size is so close I never noticed. More info for the collective reference catalog...
Mike O'Meara
Reg #1043
72 911T
56,59 356s gone
67,68 912s gone
I tried to take a switch apart to paint the bezel with chrome spray paint, but stopped before beaking something. Is there a way to remove the toggle switch button, so that I can just spray paint the bezel?
George Mihalko
S Registry #1130
R-Gruppe #540
1973 911 S
1972 911 RS Replica
1960 Roadster
2006 S Cab
Alan,
Could you send me pictures or post them please?
-Mike
mdileo@thepocketsolution.com
