Thread: What size pin wrench for SWB Boge nut?
    I cannot bring myself to use a pipe wrench for this application like so many generations of previous owners.
    The wrench looks like the below, and the nut is also shown (thanks Bob Fleming for the photo!)
    There are two measurements- diameter of the pins and the distance between them. I don't have my gland nut handy but maybe somebody does.
    Thanks!
    This isn't likely to help you one iota but BMW uses a similar setup on their wheel hubs on the old stuff. I have one that is adjustable by moving pins to alternate locations on the handle. This one can be used with 2 or 4 pins installed.
    59 across the top
    52 across the threads
    4-5mm pins
    It is the only clean way to remove them.
    Tom
    Early S Registry #235
    rgruppe #111
    Hi John,
    You need a pin spanner or pin wrench. I bought mine from Grainger. They carry Proto which is a great quality tool mfg.
    Check out this link, http://www.grainger.com/Grainger/spa...-9a8?op=search
    Best regard,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Just checked a spare Boge strut nut. The hole is 6mm across.
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Quote Originally Posted by Brad Davis View Post
    Finally checked this, the pins are 38mm apart on center. (The outside measurement is 44mm, minus one 6mm pin = 38mm) just like measuring a connecting rod. . .
    So a 38mm wrench with 6mm pins, preferably with 3/8" socket.
  1. Replies: 0
    Last Post: 11-24-2013, 01:53 AM
  2. WTB - Tool Kit Klein spark plug wrench and 17/19 wrench
    Last Post: 03-25-2012, 09:24 AM
  3. Replies: 4
    Last Post: 03-07-2012, 04:33 PM
  4. WTT or BUY 911 Generator wrench, 356 Spark Plug wrench
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 02-18-2008, 07:08 PM
  5. What size wrench for Speedo Cable? 20mm?
    Last Post: 12-29-2005, 06:05 AM
