Results 1 to 8 of 8
Thread: 1968L (?) with 911S VIN?
    I have a 68 with vin number 11805356 but the aluminum tag under the hood says "911L". My book is showing it as an S, any ideas?
    its an "L"
    VIN for S is 11800xxx for coupe and 11850xxx for Targas
    see this http://www.elferhelfer.com/fzident/fzident68.htm
    Richard aka le Zookeeper
    early reg #1128
    Thats odd, im not showing any model other than an S with the fourth digit in the VIN as a "0".
    Jun 2003
    Bend, Oregon
    As I mentioned in a recent post, I find the VINs and production numbers listed in the Red Book to be confusing. It identifies a 0 in the fourth position of the VIN as an S Coupe. This is how I understand the coding:
    First two numbers: 11 = 911
    Third number: 8 = 1968
    Fourth number:
    0 = S Coupe
    1 = 911 Coupe
    3 = U.S. 911 Coupe
    5 = S Targa
    6 = L Targa
    7 = T Targa
    8 = U.S. Targa
    Fifth, sixth, seventh & eighth numbers = serial number
    However, in the chart of production numbers there is a conflict with this numbering scheme: 11805001 is listed as a U.S. 911L Coupe, which would apply to your VIN of 11805356. But the 0 in the fourth position should indicate an S Coupe.
    That same line has another mystery. It shows a range from 11805001 to 118055449 which, with nine digits, contradicts the VIN format of 8 digits. This would throw the calculation of production numbers way off if incorrect.
    Is there a way to dig more deeply into the 1968 VIN's and production numbers? I'm not sure what source Paternie used for his great reference, but there appear to be some discrepencies.
    John Audette
    Oct 2008
    Burford, ON, Canada
    This is my VIN list for 1968
    11880001 11880268 USA 911 Targa
    11835001 11835742 USA 911 Coupe K
    11830001 11830473 USA 911 Coupe
    11855001 11855134 USA 911L Targa
    11805001 11805449 USA 911L Coupe
    11820001 11820928 ROW 911T Coupe
    11825001 11825683 ROW 911T Coupe K
    11870001 11870521 ROW 911T Targa
    11810001 11810720 ROW 911L Coupe
    11860001 11860307 ROW 911L Targa
    11800001 11801267 ROW 911S Coupe
    11850001 11850442 ROW 911S Targa
    11899001 11899020 911R Coupe
    Senior Member rgrimm's Avatar
    Jan 2006
    Fargo, ND
    Well, Davep's list works for me!
    But I know what you mean. Some of the lists are just "misleading" to put it mildly. Using one of them, I once asked my wrench if it was possible I had an S. The look on his face was something else !
    Roger
    68 Sand Beige 911 Coupe #11830091
    84 Moss Green 911 Carrera
    Jun 2003
    Bend, Oregon
    Great info, Dave. This differs from the Red Book listing:
    Red Book:
    11855001 11865134 USA 911L Targa
    Dave:
    The 6 in the 4th position appears to be a typo in the Red Book. Their version would indicated 5,134 USA 911L SWT's and Dave's version indicates 134.
    Red Book:
    11805001 118055449 USA 911L Coupe
    Dave:
    There appears to be an extra 5 in the Red Book. If you calculate the production according their VIN series it comes to 50,449, even though they show a figure of 5,449 which is probably correct.
    John Audette
    Oct 2008
    Burford, ON, Canada
    Thanks. I've put a lot of effort into working out the correct VIN ranges for the cars, and the serial ranges for the engines and transmissions. There is so much bad or misleading info out on the web.
  1. More info required on 1968L
    By autobahnx in forum Technical Info
    Last Post: 12-12-2012, 05:58 AM
  2. Replies: 11
    Last Post: 12-10-2012, 11:13 AM
  3. FS-early 911 'S' and 'L' interior trim pieces 1967S and 1968L
    Last Post: 03-23-2012, 04:52 AM
  4. FS-NOS 1968L owners manual oem
    Last Post: 07-07-2011, 10:09 AM
