Thread: Rear caliper piston alignment?
    I am rebuilding my rear calipers(1971 911S). I just want to be sure I align the pistons correctly. Any comments?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Jan 2007
    North of the GG Bridge
    The alignment differs from left to right based on rotation of the rotor and caliper position. Hope this helps.
    Piston alignment
    There is an excellent article in the April issue of Excellence magizine titled "brake time" on the subject. Bob Schwartz
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Use the bleeder as your guide. Make sure it's on top. Then imagine the rotor running through the gap as the pictures in the second post (our calipers are all in front of the axle).
    Looks like you have your template but, for those without; simply align the bottom notch in the center of the pad cavity. This will give you a 20 degree angle. I've modified the picture so you can see what that looks like...
    Also, if you want them to be accurate for restoration purposes, have them do a quick dip in the yellow.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
  1. Rear SWB vented caliper kit. (all new parts)
    By Alan.uk in forum Technical Info
    Last Post: 10-28-2019, 08:43 AM
  2. Rear Caliper Identification: Ate 51R
    By Djthom in forum Technical Info
    Last Post: 11-19-2013, 04:53 PM
  3. rear brake caliper
    By Francois Duval in forum Technical Info
    Last Post: 11-30-2009, 05:26 PM
  4. 4 piston brake caliper kits
    By endo911rs in forum For Sale: 911 Parts
    Last Post: 03-02-2007, 11:41 AM
  5. Rear bumper guards alignment
    By beginner in forum Technical Info
    Last Post: 03-03-2003, 08:40 AM
