Thread: Speedometer bulbs
    Speedometer bulbs
    I have my speedometer out of my 72E and one of three three bulbs is not currently working. It is the the one on the green/white wire. The other two bulbs are on black/blue wires and are on when the light switch is on. Does anyone know if the green/white wire bulb is activated from another switch? The reason I started this project was because the ground wire came off the speedometer and none of the three bulbs worked.
    Craig Williams
    Eugene,OR
    Member #1070
    1972 911E Targa Puck
    White/Green
    White with Green Stripe is for the green parking light at the bottom of the speedometer.
    George Mihalko
    S Registry #1130
    R-Gruppe #540
    1973 911 S
    1972 911 RS Replica
    1960 Roadster
    2006 S Cab
    Black/Blue
    The Black with Blue Stripe lights are for the gauge illumination and come on when the light switch is pulled to the first and second position. The green parking light indicator at the bottom of the gauge only comes on when the light switch is pulled out to the first position and goes back out when the light switch is pulled to the second position. If the green parking light does not come on at all, check if the bulb is burnrd out.
    George Mihalko
    S Registry #1130
    R-Gruppe #540
    1973 911 S
    1972 911 RS Replica
    1960 Roadster
    2006 S Cab
    Problem Resolved
    George
    Appreciate the reply you were spot on, light now comes on when light switch is pulled to first position. You saved me a lot of time. Thanks
    Craig Williams
    Eugene,OR
    Member #1070
  1. LED light bulbs
    By Haasman in forum Technical Info
    Last Post: 03-02-2023, 09:30 PM
  2. FS: 6 Volt bulbs
    By stephers in forum For Sale: 911 Parts
    Last Post: 01-22-2014, 11:57 AM
  3. TTG 118 Bulbs
    By Dave Pugh in forum General Info
    Last Post: 12-27-2012, 02:03 PM
  4. Gauge Bulbs
    By joetiii in forum Technical Info
    Last Post: 03-05-2007, 01:27 PM
