OK so if you would like something a bit different and want the look of the factory steel wheels how about a set of these? I had a set custom made for my IM-6 project. You can have them made to any width, diameter or offset you like. It is a three piece design starting with a billet center like a BBS wheel with hidden inside bolts so you can bend an outer or inner and replace the the rim just like a BBS wheel. This example wheel is built to the 7" 911 RS Fuchs spec. It is polished and ceramic coated at an extra charge.
Pricing would be $3,000 about per set delivered to your door depending on options like painting, polishing or ceramic coating. So far I have the only set known to man but I know where to have them built.
Contact me if you have any interest. I'm trying to develop the market and can place an order if there is interest.
