Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: What horn is right for a 1966 911?
    OK, I see what the BACK of the horn looks like. . .
    But I wonder what the FRONT looks like? I know it's not the "snail shell" type as that is an SWB horn from 305100 (1967 Model Year "official" cutoff). . .but is it flat or does it have a grill? A, B or C
    Thanks!
    A
    Richard
    Thanks Richard! That was fast.
    There sure are a lot of different frequencies.
    901 635 102 00 . . . .911 coupe -68, low pitch 390Hz, only with
    901 635 112 00 high pitch 520Hz
    this pair only through chassis 301224
    901 635 102 01 . . . .low pitch 290Hz, only with
    901 635 112 01 high pitch 345HZ
    this pair from 301224 through 305100 (start of '67MY)
    then there is the 912 set. . .
    902 635 112 00. . . .low pitch 335Hz and
    902 635 112 00 . . . .high pitch 400hz
    these only through 354000 (Porsche) or 458100 (Karmann)
    According to the Mercedes guys,
    The official Bosch data, for what its worth, indicates we had two tones, middle and high, indicated by a 3/4 or 9/10 suffix designation on the horn tag. The 3/4 were on early cars, the 9/10 were on later cars.
    3 or 9: 290 Hz Tone
    4 or 10: 345 Hz. Tone
    Guess I better bring a tuning fork to the Junkyard! Here is a link to what they sound like (volume DOWN) http://www.wolo-mfg.com/306-2t-stereo.wav
    Turns out Bosch has reproduced these for certain cars. . . .http://www.automotive-tradition.de/e...file_Horns.pdf
    Below are the Bosch numbers.
    C is 912
    B is late 60s? 912??
    Richard
    Semjon Semjon's Avatar
    Jun 2005
    Groningen, Netherlands
    Also have model A on mine (302831)
    Early 911S registry member #1391
    Built '65, MY66 911 in total restoration
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    model A
    on 304863 67 911
    horns
    A as well on mine. You can get replacement tags from Sierra Madre Collection.
    Mshaver51 wrote:
    i have a '68 project underway. the parts manual that i have isn't clear (or at least i can't figure it out) about which type of horns would have come with my car. the parts manual shows two types of horns in photos (snail shell horns and round horns (similar to the 356 horns)), and also has numbers for what appear to be other horn types. i've also seen trumpet-type horns for sale.
    can anyone tell me which horn would be proper/original for #11880001?
    thank you, as always.
    From 305100 (1967 MY cutoff chassis number) the snail-shell horns are correct.
    If you look at 901 635 112 02 you can see that that was used from 305101.
    The Bosch lists are not much help, they list the old UFO shaped type.
    Sep 2006
    La Quinta
    My '67 has horns like #65...it's really loud and sounds like a Buick!!! What's the deal with that...anyone know?
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Quote Originally Posted by John Straub View Post
    According to the parts book, your '67 SHOULD have those horns, they were used from 305100 onward.
    As far as sounding like a Buick. . . that would have had an AC DELCO horn back in the day, also a snail-shell type and probably also in the Key of F.
  1. WTB Nardi/Personal Horn Horn Button
    By 50/50 in forum For Sale: 911 Parts
    Last Post: 03-22-2011, 08:31 AM
  2. Early 911-912 horn button 1964 1965 1966
    Last Post: 07-14-2009, 10:40 PM
  3. Replies: 9
    Last Post: 10-03-2006, 11:34 AM
  4. Fs 911 1966
    By Zithlord in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-06-2006, 04:07 PM
