I am offering a 67 911S long block unbuilt. Components include choice of 2 early cases with countershaft [ 9603xx or 9609xx], head set, std.-std. crank, S rods, excellent original 67S cams and rockers, cam towers, chain housings, yellow tag dist., excellent original piston/cyl. set, 12 new Ate valves, 12 new valve guides, new Ate ring set, new JWISS chains and guides, new OEM rod bolts and nuts, Glyco main and rod bearings. Build a 67S motor with all OEM parts. Offered for $6500 firm.SOLD Original 67S induction also offered to buyer. Photos will be available. Thanks, Rick
