Results 1 to 10 of 10
Thread: 73 S spark plugs
    73 S spark plugs
    I've got a 73 S that runs very well but the plugs foul-up if it doesn't start the first time. I've got Bosch platinum W3DPO. Should I be using something else?
    1973 911S
    1967 Alfa GTV
    2002 Miata
    Is your CDI operating properly as this should not be happening? If the CDI box is 100%, how rich are you running?
    RGruppe member 445
    Switch to Nippondenso or NGK and check your mixture. Those new platinum plugs are not the same as the old 265 p21 that was originally on this car. I can't remember what the NGK equivalent is.
    NGK Iridium BP8es should work well.
    the 3's are too cold. you should be using 5's or 6's.
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Oct 2005
    Minneapolis, MN
    Keep in mind NGK and Bosch are opposite as far as heat range goes....definitely run a hotter plug...
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    The DPO's are the same good plugs as the old P21's; only the designations are different.
    Now,....3's are far too cold for street use in these cars due to the state of gasoline chemistries and I'd suggest a W5DPO or a 6 or 7 in an NGK.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Quote Originally Posted by Steve@Rennsport View Post
    In my 73S, I use NGK #7's for the street. It runs OK on the #8's, however, it starts and idles much better with 7's.
    Senior Member ThomasTe's Avatar
    Jan 2005
    Denmark, Europe
    Thomas
    1973 911S Targa
    Steve is right, same plug different number. I run W4CS. It is a heat rang hotter and has a silver tip. Stay away from the platinum wire plug Bosch makes, where you cant see the tip outside the porcelain.I perfer Bosch for there plugs plating over others. Gordon
  1. 2.2 spark plugs
    By TZombek in forum Technical Info
    Last Post: 11-27-2012, 11:43 AM
  2. Spark Plugs Help
    By denson in forum General Info
    Last Post: 09-13-2008, 04:28 AM
  3. Spark plugs---which?
    By Zeke in forum Technical Info
    Last Post: 02-16-2004, 09:18 PM
  4. Spark plugs for '73 S
    By jayzoll in forum Technical Info
    Last Post: 12-22-2003, 06:58 AM
  5. '73 S spark plugs
    By Plays with Cars in forum Technical Info
    Last Post: 05-22-2002, 12:52 PM
