Early911sregistry,
I am selling what I am lead to believe is a 2.7RS or 2.4s replacement engine. I am not an engine guru, so anyone with advice please chime in. This engine has the European Spec 2.4S MFI pump, correct 2.7rs/2.4S stacks and throttle bodies. It has the correct 2.7rs/2.4s heads. There is no engine type number stamped and it appears that someone has attempted to stamp the engine 664002, however the indentations are not very deep. I was told that the 2.7RS jugs have 12 fins and the 2.4s jugs have 14 fins. Is this correct? If this is correct then this engine has the 2.7rs pisons and jugs. And would be a 2.7rs engine minus the correct MFI pump.
This engine was running about 2 years ago and turns over. The MFI is in need of being rebuild from sitting. I am confident that there is somone on this board that wants this engine or knows what it is. I am asking 10,000 or feel free to make an offer.
BRad
http://s263.photobucket.com/albums/i...002/MFIEngine/
