Thread: Right dash face material ?
    Feb 2005
    Montreal, Canada
    Hi,
    Does the material offer by Pelican have the right pattern to redo the dash of a 70S ? (see photo)
    The other option I found is a door panel of a 914, is it better ?
    Thanks !
    JD
    Jul 2003
    Santa Cruz, CA
    Can't comment on the Pelican material but, I'd go with the 914 panel or find a warped 911 panel to get the material. That is what I did.
    The main difference I've seen between the newer vinyl and the original is the color/depth of the black. Once you start throwing new vinyl in you will see a difference.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    You should speak with Tony at autobahninteriors.com. Not only will he know, but he most likely has exactly what you are looking for.
    RGruppe member 445
    Apr 2004
    35,000 ft
    Pelican claims it comes from autobahn...it might be more cost effective to buy direct from Tony, plus you'll get good advice, but I'd assume there's nothing wrong with the pelican part.
    http://www.pelicanparts.com/cgi-bin/...C%20One%20roll
    Lewis
  1. WTB: aluminum dash face for 67
    By Frank Beck in forum For Sale: 911 Parts
    Last Post: 12-07-2012, 08:30 AM
  2. Dash face color (Satin Black?)
    Last Post: 08-07-2011, 12:51 PM
  3. WTB - Dash face plate for radio (71 Targa)
    By res0ca5d in forum For Sale: 911 Parts
    Last Post: 12-30-2006, 05:09 PM
  4. Repainting Dash Face
    By Tyson in forum Technical Info
    Last Post: 10-12-2005, 03:45 PM
  5. adhesive for dash face?...
    By joelrkaplan in forum Technical Info
    Last Post: 11-24-2003, 08:25 AM
