Results 1 to 10 of 10
Thread: Extended Hub Steering Wheel Questions
    Jul 2008
    South Florida
    After seaching previous threads regarding extended hub wheels, I still have a couple of questions and hope someone can help:
    Were aluminum wheels early, steel later? What model year did this change if so? According to the accessories booklet,
    it appears leather-wrapped wheels are steel only. Is this correct?
    I have an early (though undated) wood extended hub, is this for 912 as well as 911, and what does the "1959" stamp mean?
    Finally, does anyone know of a source for the longer horn contact required?
    Thanks for any assistance!
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    you can find them here
    www.sierramadrecollection.com
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Has anyone ever used this from the same source:
    http://www.sierramadrecollection.com..._detail&p=1602
    I would like to add the extension for my 380mm, but I would like to know what is involved and if this will work for a 911 (cancel ring being different than a 914).
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Yes I purchased one and it was Original Equipment and worked perfectly.
    Stoddard sells the extra long contact as well.
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Extended hub
    The one pictured before only fits a 914, you need it custom made, or buy it from Zuffenhaus: http://www.early911sregistry.org/for...ad.php?t=25159
    You will need this insert: http://www.early911sregistry.org/for...ad.php?t=19255
    And the 73mm 914 horn contact, which has the correct length, part No. 914.347.832.00
    My early MY66 car had an extended wood wheel on the kardex (October '65 build) and had departed the car prior to my owning it. Fortunately, I found a pefect one and that is what the car has now. My wheel has steel spokes - I have never seen an extended hub wheel with aluminum spokes.
    I bought my extended contact from Stoddard.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Jul 2008
    South Florida
    Thanks for the input regarding the horn contact guys, anyone know what the numbering means? Production? Are these pre-'66?
    Thanks also to Kenikh... interesting that your MY66 wood wheel is steel. The one pictured is alloy (including the extension) and is incredibly light.
    My understanding is that these alloy wheels flexed too much, cracking the wood, so steel versions replaced them. Anyone know when that change occured?
    Russ
    ESR # 1537
    '70 914/6 GT
    I seem to recall a thread here that had a pretty good guess, but don't recall. I think it was likely posted by Soterik.
    My understanding is that the real reason the spokes were changed from aluminum to steel was safety. Apparently after some pretty ugly incidents involving snapped spokes nearly severing some hands in accidents, Porsche changed to steel to ensure there weren't any bleed outs in crashes.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Extended Hub - original Alloy Spokes
    [QUOTE - I have never seen an extended hub wheel with aluminum spokes.QUOTE]
    Kenik,
    FYI my original and unmolested early '65 901 has it's original equipment extened hub alloy wheel.
    It had "flexed" and at some point it has had some re-inforcing affixed to the spokes. But it is original given the car's provenance- so one could order them early in the '65 911 build.
    I didn't realise it apparently is "rare".
    Cheers
    Stew.
  1. WTB: Extended Hub steering wheel spacers
    By Nicklasliljegren in forum For Sale: 911 Parts
    Last Post: 05-09-2013, 12:22 PM
  2. FS 1965-73 911 Extended Hub Steering Wheel
    By cog in forum For Sale: 911 Parts
    Last Post: 09-23-2012, 02:35 PM
  3. 380mm 914-6 steering wheel with extended hub FS
    By byron in forum For Sale: 911 Parts
    Last Post: 02-13-2009, 08:07 AM
  4. WTB: Extended Steering Wheel Hub
    By a911s in forum For Sale: 911 Parts
    Last Post: 04-01-2008, 07:10 PM
  5. Extended hub steering wheel question.
    By gtgroupe3 in forum Technical Info
    Last Post: 09-15-2007, 05:15 PM
