Thread: Rear bearing press/banana refurbish
    Made a press from cheap materials. Powder coated the black parts, blue and yellow zinked parts. Put the bearing in the freezer and it slit right in with the home made press and 8t jack. Used a very tiny bit of grease on the bearing cavity in the banana arm and the old bearings to press inn the new ones, because you should only press at the outside of the bearing when you press it in.. Also a 78mm wide plate between the old bearing and the top of the jack, because the jack top is to narrow. I also pressed in the hub with smaller presses that just press the inside of the bearing. BTW the picture of the press shows the new bearing pressed all the way inn(you can not see it) and the two old bearings on topp and at the bottom.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    final picture
    nice work, I did the same to mine powder coated and replated, should hold up better than the original paint.
    John, thanks for posting the pics-- very nice!
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Mighty fine work John!
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
  1. FS: Rear Banana Arms SWB
    By 68911+1 in forum For Sale: 911 Parts
    Last Post: 02-26-2013, 05:12 PM
  2. 1970 911 Love Story brochure, press release, press photo
    By 88cs in forum For Sale: 911 Parts
    Last Post: 06-16-2012, 01:03 PM
  3. stuff for Hershey -rear window, SWB banana arms, etc
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 04-08-2012, 09:36 AM
  4. Leftovers: rear banana arm bushings, coil mount clamp
    By Eminence Gris in forum For Sale: 911 Parts
    Last Post: 10-30-2010, 10:24 AM
  5. Woo Woo Woo sound from rear end....maybe rear wheel bearing?
    By Chris Tallon in forum Technical Info
    Last Post: 06-27-2007, 06:59 AM
