Thread: 2.0 to 2.2 upgrade
    2.0 to 2.2 upgrade
    am considering in the near future to rebuild my 2.0 1969 T engine.
    while at it i am considering to upgrade its performance whilst remaining with the original matching-numbers case.
    can someone explain to me the pros and cons of wayne dempseys e-cam upgrade and 2.0-2.2 upgrade below. my feel is to go for the 2.2 upgrade.
    (will the 2.2 upgrade give me the same HP (180) and performance as the 1970 2.2S engine??)
    __________________________________________
    Paul
    1967 911 coupe polo red (gone)
    1969 911T coupe tangerine(present)
    1973 911T targa arctic white (gone)
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by red67 View Post
    The simple answer is no. Not unless you use the 2.2S pistons, cylinders, cams, heads, distributor and fuel injection system; basically everything outside the crankcase needs to be correct 2.2S parts to equal the 2.2S performance.
    An 'S' compression 2.2 with Solex cams will get yout near 160 HP and is lots of fun.
    I'd recommend going with a "mod" grind like the Mod-E, Mod-S or Mod-Solex. The regrind cost of a normal, E, S or Solex cam is well worth it.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. H4 Upgrade Kit From Pelican
    By mfitton in forum Technical Info
    Last Post: 10-19-2012, 08:15 AM
  2. Got the upgrade bug
    By EA911 in forum General Info
    Last Post: 09-28-2010, 09:29 PM
  3. H4 Upgrade
    By 356robo in forum Technical Info
    Last Post: 12-14-2008, 05:20 PM
  4. S caliper upgrade
    By mike walker in forum Technical Info
    Last Post: 08-30-2006, 09:59 AM
  5. Spec 2.7 rs upgrade
    By VIper Green E in forum General Info
    Last Post: 05-10-2005, 06:09 AM
