Results 1 to 10 of 20
Thread: Do I have 68 L brakes?
    I came across a set of front struts with 3.0 inch holes for the brake calipers. So I am assuming they are for a SWB car. The front brakes themselves have ventilated disks. The calipers are not aluminum. These parts were found with a 68 L motor. Would a 68 L have had S brakes? Would those brakes be made of steel? I want to put these on one of my 66 911 cars. Any help would be appreciated as my research has not yielded anything conclusive.
    Dec 2006
    Las Cruces, New Mexico
    Yes a 68L would have had the same brakes as a 67S, a 68S was not offered for the US market it was an emissions reg thing. The L used a 'normal' 130HP engine in lieu of S 160 HP all else same as S car.
    Early 911S member #166
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Those are standard M-Calipers. Came on the 67-68 911S and then moved to the rest of the line in 69 through 77. They would bolt on to your 66 car but, with that hub, the nose may rub on the wheels if you use the vended rotors. It's basically the same thing that's on a 66 (little different in the casting) but with spacers and longer fasteners.
    Hope that helps.
    E.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Rubbing concern
    Thank you Mark and Eric for the responses.
    Eric, can you clarify your concern about rubbing? Presumably they did not rub on 68 cars. What would I have to do to make them work on the 66? Since the car in question does not have any suspension on it, I can put the complete 68 suspension if necessary. Also, this car is a R clone with wider front fenders, so fender rub is not a concern.
    Thank you for you thoughts,
    Regards,
    I believe the only difference on '68 vs earlier SWB is a 7mm spacer on the back and a 7mm wider hub on the front, to account for 5.5" wheels.
    The S brakes on SWB are the same and not aluminum like later cars. I believe only the 67S, the 68S and 68L, and all sporto cars had the S brakes from the factory.
    My '68 is a "base" 911 but was originally a sporto so it has the SWB S brakes, vented all around.
    Die schönste Rennstrecke der Welt. Nordschleife's Avatar
    Dec 2006
    Here's the thread you need, John...
    Hi John,
    Eric ("Neunelfer" here on this Board) does superb work on these earliest 911S / 911L brakes; he restored a similar set for me. Here is the thread with photos, it might help: http://www.early911sregistry.org/for...dy+brakes+1968
    Best Regards,
    Andy
    Early 911S Registry #1246
    1968 Porsche 911 Cotswold Blue/Schwartz #118 35153
    1962 Marcos G.T. 1000 Gullwing historic race car - now sold and racing in FIA events in Sweden
    "Pro Patria Vigilans"
    Oct 2008
    Burford, ON, Canada
    I understand that the aluminum S caliper was introduced late in the 1968 model year. Does anyone have factual information on this. I assume it would mean that the same struts as used on the 1969 and later models were used.
    Dec 2002
    Sandy, Utah
    Do that and you'll not only be better off, you'll be fine with regard to the rubbing. I was thinking that if you bolted those and some vented rotors to the shallower 66 hub, the wheel would rub on the caliper.
    Thanks Andy! Checks in the mail... LOL
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    Steel "S" Brakes-Yes, Rear-No
    Thank you all for steering me to the right information. What I have learned is that I have 3 sets of these wide-L front calipers, but no rear ones. While it is not imperative, I would certainly like to find a set for the rear. Are they available? Anyone have a set? After reading everything here, I will probably have Eric restore a set for my current project, and I will save the other sets for my other 66 cars.
    Thanks all for the fantastic help.
    Regards,
    Finally crossed over here, eh John? Welcome!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. Replies: 43
    Last Post: 01-16-2014, 03:10 PM
  2. Replies: 11
    Last Post: 12-10-2012, 02:58 PM
  3. Brakes, which way to go
    By Max (SD) in forum Technical Info
    Last Post: 07-14-2011, 10:21 AM
  4. Who wants some SWB big brakes?
    By mjmoran in forum Technical Info
    Last Post: 12-22-2009, 12:01 PM
  5. Brakes For '67 911
    By jaudette3 in forum Technical Info
    Last Post: 08-11-2006, 07:33 PM
