Results 1 to 2 of 2
Thread: Question for the electronic gurus
    Sep 2008
    Portland, OR
    My question is probably well outside the scope of this forum, but then again I never cease to be amazed at the breadth of knowledge that exists here. As such, my question...
    Have a '66 Blaupunkt Koln that has the separate amp from radio. One of the capacitors in the amp bit the dust. My problem is, I can't tell from the markings what to replace it with... while the other bigger caps have the uF explicitly called out, this little guy is a bit of a mystery to me.
    I did put in a similar sized 10uF/16V cap I had laying around and happily now have music coming from the radio (before you could barely hear any music, the amp wasn't doing it's job). But before I solder it in, I wanted to see if anyone could identify the correct value of what it had.
    On the cap is written:
    +5/15
    ROE (in a box) H
    +EL
    Pic attached. Thanks in advance if any of you electronics gurus know the value of this...
    Attachment 81153
    Attachment 81154
    Thanks!
    Pat
    Patrick... Member #1707
    '58 356
    '67 911
    '69 911
    Capacitor
    5 ufd, 15volt rating.
    Your 10 ufd 16v will work just fine.
    1967 911
    SN 307012
    EN 911-008
  1. WTB: Late 70's Blaupunkt Electronic Cassette Radio
    By Strato 102 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-05-2014, 07:27 AM
  2. Becker Grand Prix AM-FM Electronic Tuning
    By sithot in forum For Sale: 911 Parts
    Last Post: 08-30-2012, 02:15 PM
  3. Installing Pertronix Electronic Ignition
    By shipard in forum Technical Info
    Last Post: 08-31-2008, 05:22 AM
  4. Advise on Electronic Ignition please.
    By 72911E in forum Technical Info
    Last Post: 10-15-2007, 05:17 AM
