Thread: Gas tank Seal gasket
    How thick should it be? And where does it go?
    The one I have is about 1/2" thick.
    I assume it goes on the flange.
    it's dense foam and the tank sits very high.
    I'll never get the mounting clips screwed in.
    It looks best with no seal.
    I'm tempted to just run a bead of silicone.
    HELP!
    bob moglia
    '72 E sunroof coupe
    Dec 2006
    Las Cruces, New Mexico
    Yes it is sealed on the flange, black silicone or the stuff they use to seal new windshields is what I'm going to use. Something similar was used at the factory @ least in 1967 it will also seal much better than the foam 'weatherstrip' the vendors are selling.
    Early 911S member #166
    I can see where the concern would come from with a high profile-high density foam type seal. The ones I have seen and used are not either and provide an adequate seal if things are straight and mate well. Otherwise, maybe use the goo MarkS is talking about.
    I'd not want to think about the difficulty in removing the tank at a later date if butyl is used.
    the one i have came with my pan, old tweeks stock from
    the 90's. i'll go to the hardware store and get some weatherstrip.
    thanks guys.
    bob moglia
    '72 E sunroof coupe
  1. 901 seal and gasket kit quality
    By rdelmendo in forum Technical Info
    Last Post: 11-24-2013, 07:28 AM
  2. Gas tank gasket seal
    By merbesfield in forum Technical Info
    Last Post: 10-20-2013, 05:17 AM
  3. FS: NOS Gas Tank Seal
    Last Post: 06-23-2009, 04:39 PM
  4. Is it necessary to seal a gas tank after cleaning?
    By Alan B in forum Technical Info
    Last Post: 04-14-2008, 11:51 PM
  5. WTB: gasket for fuel tank sender
    By Zithlord in forum For Sale: 911 Parts
    Last Post: 03-31-2007, 07:33 AM
