Thread: FS 380mm "RS" STEERING WHEEL
    Needing better direction folks,
    Here is a very nice 380mm steering wheel. Part number 914.347.809.10, this is an OEM simulated leather wheel in nice shape. Date code is 10/75. The grip is ~3" as shown. This is a 914-4 wheel that I've drilled and tapped on the back side to take a 911 turn signal cancel ring. The wheel is a bolt-on for 911s up to and including 1973. This wheel has really nice original paint and is very serviceable for a nice "driver" Porsche. Price shipped in U.S. is $200, outside U.S. $240. If you'd like the cancel ring add $65 (yes, that's what they cost from Porsche)Please note your existing cancel ring may need very minor elongation of one mounting holes since I had a small problem with my "machining"..sorry(not at ALL visable, of course, once mounted). Please email direct to DrRSR@aol.com Thanks.
    -Allen-
    Maybe?
    I've exhausted the demand on the list Please pass on to your friends (bump)
    -Allen-
    Still available
    I still have this one. Thanks.
    -Allen-
  1. FS: Special Extended Hub 380mm "RS" "RSR" Thick Grip Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 06-06-2014, 12:47 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-17-2012, 07:56 AM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-09-2012, 07:53 PM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-03-2012, 08:51 AM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
