Results 1 to 9 of 9
Thread: accelerator rod bushings
    I will be replacing the broken hand throttle drag link and was advised to check out the accelerator rod bushings - I have found them in my parts book and there are three.
    Where in the tunnel are they?
    I hear the rod rattling around a bit but I think it may need to have the slack taken out and it may not a bushing problem.
    thanks.
    73 911S Targa
    Bob, the bushings are; under the shifter, under the hand brake assly, and under the rear tunnel cover. The noise you hear is the throttle rod clanking around in its brackets, because the bushings are gone. The pictures are from a presentation I did at last years Parade on fixing this very issue.
    great help - thanks!
    73 911S Targa
    And get your wallet ready. . . $15 EACH
    got my bushings from my local dealer - they give a 10% discount to PCA members.
    got the old broken up pieces out (at least on the rear 2, haven't found the front one yet).
    any tips on installation? it seems like a reach to force the new bushing in laterally, but the middle holding "clip" is a complete circle and I see no other way.
    should the clip be opened up by bending and then bent back?
    thanks.
    73 911S Targa
    Dec 2006
    Las Cruces, New Mexico
    [QUOTE=Boulder Bob
    thanks.[/QUOTE]
    Yes the clips should be opened up by bending and bent back. It took me about a minute per bushing to replace the 3. My tunnel was nude so easy to see and get to all 3.
    Early 911S member #166
    thank you!
    73 911S Targa
    OK - I have replaced the middle and back bushings - can't find the front one - do I have to remove the shifter tower to find it?
    73 911S Targa
    Dec 2006
    Quote Originally Posted by Boulder Bob View Post
    OK - do I have to remove the shifter tower to find it?
    Yes you do Bob.
  1. Weber Accelerator Pump Problems
    By Fishcop in forum Technical Info
    Last Post: 08-06-2013, 08:41 PM
  2. WTD: Lever for WEBER accelerator
    By ydderf911 in forum For Sale: 911 Parts
    Last Post: 04-21-2012, 02:03 AM
  3. WTB Weber Accelerator Pump Rod
    By Fishcop in forum For Sale: 911 Parts
    Last Post: 09-09-2011, 04:00 AM
  4. Accelerator Pedal question
    By TKO in forum Technical Info
    Last Post: 07-26-2004, 09:15 PM
  5. Accelerator linkage
    By mwalker09 in forum Technical Info
    Last Post: 09-28-2001, 09:48 AM
