My 70 911 only sees about 2500 miles a year of casual street driving. What is the recommended brake fluid change interval in years?
Thanks in advance,
Rob
Thanks in advance,
Rob
356Robo
64 C Coupe #218448(sold)
70T Targa #9110110416(sold)
15k or two years which ever comes first.
Tony Proasi
52 split window coupe
As posted on pelican under this question... mileage is not the concern, it is exposure to water. Change it every 1-2 years with new fluid. If you open a bottle and don't use it all it is no good after some time (3 months max) due to water absorption.
1968 911S 30K miles
2006 Saturn Ion DD
1988 Beretta GT
1981 5-Ton Chevy stake-bed
Air goes in and out, blood goes round and round, any variation of this is a bad thing.
+1 docrodg, brake fluids are hydrophilic, i.e., absorbing moisture even from the atmosphere. Flush and replace every 2 years minimum,
especially if you live in a humid location. Even if your brake lines are stainless.
High performance silicone brake fluids are even more hydrophilic and generally shouldn't be used in street applications.
A track car's brakes see duty that requires frequent servicing, including fluid flush/replacement.
Russ
ESR # 1537
'62 356S Notchback Hotrod
'67 S Das Geburtstagsgeschenk
'68 T Targa Sportomatic
'68 L SW Targa Sportomatic
'70 914/6 GT
Thanks for all the responses. I have to admit that its been 5 years. So, what should I look for related to the possible moisture issue? What fluid is recommended?
Thanks again to all,
Rob
356Robo
If the car sees ANY track duty, you are crazy to have brake fluid older than 6 months. Our PCA region insists that brake fluid be less than 6 months old to attend a DE or autocross event.
Tom Tweed
Early S Registry #257
R Gruppe #232
PCA National DE Instructor
Read my surf novel!
Hydrophilic? Close, HYGROSCOPIC. In Mercedes Benz school, a hundred years ago...were taught "every two years preferrably in the spring"
^^^ A fine distinction as both mean almost the same thing... but you're right, hydroscopic is more correct. My bad.
Russ
ESR # 1537
'70 914/6 GT
