Thread: Fs 1967 911S Engine and Trans! Complete ...41,000 original miles
    FS 1967 911S Engine and Trans! Complete ...41,000 Original miles
    For sale offered here first!
    1967 911S Engine #9621** 41,000 miles with matching 911S Trans #901/02...
    These were removed from a crashed 911S in 1970 and have been in dry storaqe ever since... The engine has very good compression and is 100% complete (except muffler). The original Weber 40IDS Carbs are still in near perfect condition.
    The engine has all of the original hoses and is still attached to the original 1967 oil tank! The engine still has the 6 original Bosch shrouded park plugs that have been out of production for over 30 years! Even the gold Cad plating in still nice..
    If you have a 67S that needs a good engine then this is you!! You WILL NOT find a more original engine... May consider selling engine separate from trans...
    If you were to find another 67S engine it will probably be in the $8,000-$9,000 range and will be played out and need a total rebuild. With 911 engine rebuilds costing in the $12,000-$15,000 range you could easily end up having over $22,000 in your engine...
    This engine does not need to be totally rebuilt! The engine needs a lube/tune and freshing up...
    $14,500 offers/trades Email any questions to execmalibu@earthlink.net
    Mike,
    shipping via forward air is$205
    Check from Australia is a no show... Still Available to USA 911S owners...
    I thought I would have a deposit check by now but so far NO check... This is a score for you guys with a SWB S car!
  1. Replies: 16
    Last Post: 06-11-2011, 04:16 PM
  2. Replies: 20
    Last Post: 12-25-2010, 07:25 PM
  3. Replies: 11
    Last Post: 04-11-2010, 06:19 AM
