Results 1 to 10 of 11
Thread: 1973 S MFI "The Red Shroud"
    I'm trying to get information on what type of engine shroud would be associated with a '73S with MFI. My shroud that came with the car was tattered and the previous owner removed it and put an RS shroud on the engine.
    I know the color is red and that's all I know.
    I'm a perfectionist and true to the exact build of the car. I had a conversation with Damon from Series 900 in New Hampshire today about the proper shroud.
    Is it a shroud with rivets or is it a shroud with the integrated (no rivets)?
    Damon thought there were two types available and I'm thinking maybe so with the fact CIS was used in the same year as MFI.
    Any help from you would be apprecaited before I spend the money having him make me one.
    Thx,
    Dave
    Dave Pugh
    '73S #493
    RGRUPPE #627
    http://pughmedia.tumblr.com/
    PM sent for shroud
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Nov 2002
    Fremont, CA
    Probably amber grey duct riveted on from the top of the shroud all the way to back of oil cooler.
    scott kinder
    kindersport@gmail.com
    Registry #614
    The short answer:
    73 MFI shrouds are one year only ... sort of.
    At a quick glance the early, red "S" shrouds appear to be the same as the later SC and Turbo shrouds but they have a few differences (CIS shrouds from 1973 will be a different color than the "S" shroud because they were only used on the 911T in that year). The most obvious differences are injector cutouts and the adjustment hole for MFI pump idle circuit. They also have small holes near #4 and #5 where the shroud bolts to the cam tower; the later shrouds have larger holes in those locations because of the special A/C washers.
    You will see "casting marks" for the injector cutouts on an unmodified CIS shroud.
    Here's where things get fuzzy...
    I have seen 73S engines that have a 71/72-style shroud (long, one-piece gray duct for the oil cooler). Were these early production engines? Were they original? I don't know 100% what the answer is, but I wouldn't put it past Porsche to use the 71/72 shrouds that were left on the parts shelf before they moved on to the later two-piece shroud (short, gray oil cooler duct cover).
    To further complicate the matter, Porsche used the mechanical injection, red "S" shroud on the 1973 Carrera RS (911/83 engine) as well as the 1974 European Carrera (also a 911/83 engine).
    The attached photo is of a 1971/72 and, I believe, a VERY early production 1973 911S fan shroud. Note injector cutouts and "extra" hole for MFI pump idle adjustment.
    -Marco
    TLG Auto: Website
    Hi,
    Marco is right in that I have the situation describe on several items, even body panels.
    But virtually all 2.4S covers I have seen are this design: but with the additional cut out for the injector
    HTH
    Alan
    I have a later (April) '73S
    - This is how it came off.......
    - How it went back on......
    - Detail of a page out of my '73 part catalog
    - 911.106.901.03 - S Red
    - 911.106.406.00 - Air guide plate for oil cooler
    Hope this helps,
    Cheers
    Thank you all for your insight. BIG, BIG help to have experts on demand!
    I hope I can return the favor/insight one day too.
    FYI...the car is on the road for the first time in 7 years this Friday!
    Dave
    Dave Pugh
    '73S #493
    RGRUPPE #627
    Pictures please!
    Stan Carley
    69 911S
    '73 S red shroud
    My '73S coupe was built in December, 1972. It has the original fan shroud. It looks exactly like Chuck's shroud. Also, as stated previously, I believe the RS fan shroud is the same. If your shroud is not torn up you can restore it to the original look with a little work. Check this forum for the thread. As I recall, Chuck Miller details his method for doing this and it came out great.
    R.
    Lightbulb
    Try this......
    http://www.early911sregistry.org/for...shroud+restore
    Hope it helps,
    Cheers
  1. FS: "REPA" seat belt dated label. 1968- 1973
    By stretch in forum For Sale: 911 Parts
    Last Post: 03-11-2024, 11:16 PM
  2. FS: Repro red "S" engine/fan shroud - Series 900 - new
    By campbellcj in forum For Sale: 911 Parts
    Last Post: 03-11-2014, 08:35 PM
  3. WTB: "Service Information: Model 19XX" Bulletins for 1970 thru 1973.
    By derwhite in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 02-07-2013, 03:06 PM
  4. Replies: 4
    Last Post: 12-13-2012, 05:32 PM
  5. Chilton's "Porsche 1969 - 1973 Repair and Tune-up guide"
    By peters911s in forum For Sale: 911 Parts
    Last Post: 07-14-2011, 01:05 AM
