Results 1 to 10 of 12
Thread: rear suspension height adjustment
    Apr 2004
    35,000 ft
    I'm looking to lower my '72 a 1/2" to an inch in the rear, I know the radius arm needs to come off the torsion bar, but how involved is the process? Car does not have the later style adjustable radius arms.
    been reading up on this, and doing a bunch of searches, but I'm hoping for a quick recap. I'm hoping by bushings are ok.
    Lewis
    Lewis,
    Buy one of these: http://www.homedepot.com/Tools-Hardw...atalogId=10053
    Drop me an email, and we can set up a phone call. I just did it on my car.
    Tom
    Tom F.
    Long Beach, CA
    Angle Finder - basic edition
    Here's another option, non digital but works just as well and may be less expensive. Not sure what degrees are for lowering from stock height. Stock ride height is about 36 degrees, check specs. Make sure car is level on jackstands when measuring.
    http://www.competitionengineering.co...?CatCode=10160
    John Schiavone
    Connecticut
    BTW, the later adjustable arms are great, but the factory did not use them to set the suspension when the cars were new. All of them came set at the lowest position. The idea was that the car could be raised back up, as the suspension sagged over the years. Or, maybe it was to give owners the option of going with the Safari look.
    Whatever, the Carrera shop manual has an extensive discussion of corner balancing, which is worth checking out.
    Tom F.
    Long Beach, CA
    Quote Originally Posted by Tom F. View Post
    Lewis,
    Tom
    I just bought one of those at Sears last weekend. On sale for about $34. I used one of their non-digital (analog?) inclinometers for 20 plus years.
    Measure your trailing arm angle relative to the door sill on that side. This way you don't have to worry about getting the car itself perfectly level.
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Aug 2005
    VA
    just measuring the hight at the end would give more accuate results....no?
    Chris
    Dec 2006
    Las Cruces, New Mexico
    Early 911S member #166
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    Hi Lewis,
    I have an angle locater that I can let you borrow, I'll give it to you when we meet up in NY later this month.
    I also just finished lowering my suspension recently so we'll chat more about then.
    TimG.
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
    Apr 2004
    35,000 ft
    thanks, Tim, I look forward to it.
    I'm going to leave the rear alone for now, but I do have one of the gauges shown, very similar to the competition engineering one.
    Lewis
    Jan 2007
    North of the GG Bridge
    just measuring the height at the end would give more accurate results....no?
    I think so after experimenting many times.
    For what it is worth, my rule of thumb for a SWB car is, change the measured amount from the tip of the swing arm by 1/2 the amount you want to change the height of the car. (To lower the car 1 inch then raise the swing arm height one-half inch) Yep it works.
    For a LWB car you need to reduce the amount a bit more for the longer swing arms.
  1. Rear suspension squeek Help
    By bobm in forum Technical Info
    Last Post: 11-14-2013, 07:12 AM
  2. Rear suspension crossmember 901.501.075.21
    By Richsmith901 in forum Technical Info
    Last Post: 06-10-2013, 04:55 PM
  3. Replies: 1
    Last Post: 05-07-2012, 11:35 AM
  4. RS rear suspension
    By 911pcars in forum General Info
    Last Post: 11-02-2004, 11:15 AM
  5. Height Adjustment in 73 Sport Seats
    By Silver Surfer in forum Technical Info
    Last Post: 05-07-2003, 01:55 PM
