Thread: Turn Signal Problem
    Member jkolesa's Avatar
    Royersford, PA
    Turn Signal Problem
    the left turn signals work fine. when i move the lever up for right first the right indicator on the tach flashes and then both indicators flash and keep flashing. the front right turn signal bulb flashes but the right rear does not. the right rear bulb is fine and all of the fuses appear to be as well. when i turn on the hazards all lights flash except the right rear.
    any ideas? i was thinking the turn signal switch but could that effect the hazards operation?
    1971 Porshe 911S targa 2.7 RS Carrera motor
    1991 BMW E30 S52 conversion
    2001 Volvo V70 T5
    The Netherlands
    turn signal problem
    Take the right rear bulb out, then try to lift the copper connector in the bulb housing a little up with a small screwdriver. This one probably makes no contact with the tip of light bulb.
    good luck, Cees
    Royersford, PA
    That did the trick! Thanks a million. That would have taken me a long time to find.
    2001 Volvo V70 T5
    Jun 2009
    Cape Vincent, NY
    The flashing of both dash indicators is a way of telling you that a bulb is out. Some cars do both indicators, some do a more rapid flashing.
    1968 911S 30K miles
    2006 Saturn Ion DD
    1988 Beretta GT
    1981 5-Ton Chevy stake-bed
    Air goes in and out, blood goes round and round, any variation of this is a bad thing.
  1. Turn signal problem '69 911T
    By Lord Potato in forum Technical Info
    Last Post: 11-29-2011, 12:26 PM
  2. Turn signal does not turn off once I make turn?
    By 2008SPorsche in forum Technical Info
    Last Post: 05-05-2009, 10:10 AM
  3. 69 turn signal switch, left turn works, right doesn't
    By caproader in forum Technical Info
    Last Post: 06-04-2008, 05:30 AM
  4. Turn Signal/Headlight Dimmer Lever problem
    By Torque in forum Technical Info
    Last Post: 06-28-2007, 07:16 AM
  5. Help with turn signal problem
    By Alan B in forum Technical Info
    Last Post: 11-01-2006, 02:31 PM
