Results 1 to 10 of 11
Thread: WTB Two 2.0L pistons
    Oct 2009
    Indiana
    I need two, good-quality pistons for my 2.0L re-build, if you happen to have a couple laying around. I'm trying hard to avoid being in the parts business, so i'd prefer to avoid parts-packages.
    At the same time, i wouldn't want to break up a matched set, so i'd consider that.
    thank you, as always.
    ms
    Aug 2007
    Phila Pa. area
    piston
    T, L, S ? Which type, I assume the 2.0L means 2 liter, not a 911L?
    Mike
    I should have some 911,L pistons. T and E also. Ill get a look and get back.
    May 2006
    CT
    I can provide matched singles or a set.
    You have an email from me
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Oct 2009
    Indiana
    Thanks for the good questions
    Early 911 Friends,
    thank you for the good questions. when i was restoring my '59cab, i got used to providing the details of my requests, but my knowledge hasn't progressed that far on the 911, yet. this helps.
    i think the pistons that i need are 80V37. they have the ring below the wrist pin. i think the engine was 130HP if that is helpful.
    the engine is a standard 2 liter 911 engine. to be honest, i don't know the difference between an L engine and a standard 911 engine, so you guys are helping to educate me. the case #'s appear to cover both the 911 and the 911L engine, according to the research material that i have consulted.
    While we're having this discussion, i also need a distributor cap hold-down clip for a cast iron distributor (one clip was broken), if you happen to have one of those in your stockpiles.
    i hope this additional information helps. thank you, again.
    mike shaver
    I found these 2 pistons from a 65 911. PM me if they are what you need.
    Those sure look like the ticket. Be sure to check the ring gap if at all possible. Should be fine as the forged 9:1 CR Mahles of the 911 Normal are pretty robust given the power output.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Quote Originally Posted by 66S View Post
    Did you sell these? I know someone looking for one.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    If Rick has sold them, I can probably help him out. I have used one's laying which I have no use for.
    Richard
    I can provide another 911,L piston. $20 plus shipping. PM me if you want it. Rick
  1. FS - set of '69S pistons
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 10-23-2009, 09:52 PM
  2. WTB - 2.4 CIS pistons
    By Hayden Burvill in forum For Sale: 911 Parts
    Last Post: 01-27-2009, 02:21 AM
  3. Replies: 2
    Last Post: 05-21-2008, 04:25 PM
  4. FS used 84(2,4 E) pistons
    By OliveR in forum For Sale: 911 Parts
    Last Post: 10-23-2006, 07:52 AM
  5. Are these 2.2S or 2.4S pistons?
    By Cornpanzer in forum Technical Info
    Last Post: 10-24-2005, 02:08 PM
