Photos on Ebay links.
1974 - 1989 Porsche 911 Front Sway Bar. It is 20mm diameter. This is a used sway bar. To be sold without a reserve. $17
http://cgi.ebay.com/ebaymotors/1974-...Q5fAccessories
1965 - 1973 Porsche 911, 912 Pair of Engine Lid Hinges. These are in good used condition. To be sold without a reserve. $11
http://cgi.ebay.com/ebaymotors/1965-...Q5fAccessories
Porsche 911, 930 Throttle Linkage Pivot Assembly. Porsche # 930 110 360 02 also # 19473. This is a good used part. The pivot works smoothly. To be sold without a reserve. $7
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
1965 - 1973 Porsche 912, 911 Wiper Linkage Assembly. The wiper transmissions turn smoothly. This is a good used part. To be sold without a reserve. $11
1965 - 1973 Porsche 911, 912 Brass Bushings for the Pedal Cluster. This is an upgrade sold by Weltmeister part # 102389, PB5000. This is new old stock and just what you need to rebuild your pedal cluster. To be sold without a reserve. $7
1965 - 1973 Porsche 911, 912 Brake Pedal Return Spring. This is New Old Stock. Porsche part # 901 423 531 00, 1298 CGE, 22394 To be sold without a reserve. $7
1965 - 1973 Porsche 911, 912 Speedo Cable Rubber Bellows. This is to seal the speedo cable where it comes through the body of the car and keep air and water out. This is New Old Stock. Porsche part # 901 741 291 00, 1451 CGE, 22130 To be sold without a reserve. $7
1965 - 1969 Porsche 911, 912 Clutch Fork. This is a used part in good condition. It has a Porsche part # 901 116 712 OR1 cast into it. This clutch arm operates the throw out bearing. To be sold without a reserve. $7
1965 - 1973 Porsche 911, 912 Set of Aluminum Sun Roof Tracks. These are Porsche 911, 912 Tracks which mount to the roof. Additional photos are available. Please send your e-mail address. To be sold without a reserve.
$185
1972 - 1973 Porsche 911E Passenger Side Hydropneumatic Front Strut. This is a used strut in good working condition. Its been a long time since I've found a good one of these....... To be sold without a reserve. $90
http://cgi.ebay.com/ebaymotors/1972-...Q5fAccessories
1966 - 1984 Porsche 911, 912 Sun Roof Sliding Panel and Headliner Fabric with Frame. The sliding panel is in good condition with some scratches in the paint. There is a handwritten part # 100 1177/30 on the bottom side. The panel fits many years according to the book, I have not been able to check part numbers on the hardware and clips. The headliner material is dirty and may best used as a pattern. The headliner frame appears to be in good condition. To be sold without a reserve. $145
http://cgi.ebay.com/ebaymotors/66-84...Q5fAccessories
