Thread: What is the intake port size 2.5 ST?
    Related to my question re. TB's used on a 2.5 ST (short stroke).
    What is the size of the intake port on the 2.5ST?
    - S / 36mm or was it OEM enlarged to for instance 38mm?
    Thanks again
    Richard
    I have this info somewhere and will dig it up. The question is: what are you brewing up, John? I did loads of research for my 2.3L ST replica motor and have lots to share, if interested.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Richard:
    The head ports were 41/41 mm, and the high butterfly stack TBs were also 41 mm. The best source for ST data is probably the 'Another Hotrod' thread by Flunder, but you may need to spend a little time finding the details you are after...as there are 30 pages of comments. It's time well spent though, if you are into STs.
    http://www.early911sregistry.org/for...t=23333&page=4
    Also, the Ultimate ST thread is another good source,
    http://www.early911sregistry.org/for...ltimate+thread
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  1. FS: PMO 40/35 stock Size Weber intake Manifolds
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 02-27-2014, 07:42 AM
  2. PPI recommendation in Port Tobacco, MD
    By popowitz in forum General Info
    Last Post: 01-27-2014, 10:06 AM
  3. 906 valve and port size
    By v-8 in forum Technical Info
    Last Post: 08-27-2009, 04:22 AM
  4. FS - 3.0 SC Big Port Heads
    By tom1394racing in forum For Sale: 911 Parts
    Last Post: 08-12-2007, 03:01 AM
  5. 3.0 MFI Port Size Advice Needed
    By Neunelfer in forum Technical Info
    Last Post: 01-15-2003, 09:45 PM
