Thread: L-Caliper Spacer Kit
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Turn your standard L-Calipers into "quazi" Wide L-Calipers.
    If you've ever wanted to add vented rotors to the rear of your early 911 or 912, this is the kit for you. You'll have the same pad size as the Wide L-Caliper and externally a virtually identical caliper (Wide L's use M7 Ribe Fasteners).
    So... if the 35mm piston vs. the 38mm piston doesn't bother you simply bolt this kit on and go "vented"
    $149.00 plus $4.95 shipping.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Dec 2002
    Sandy, Utah
    Bump-a-roo
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    Jan 2007
    North of the GG Bridge
    Are pins, retainers and cross over pipes available too?
    Dec 2002
    Sandy, Utah
    You Bet.
    Pins are standard 911 Rear M-Caliper pins. Retainer springs are a combo of 914 (length) and rear 911 M-Caliper (width) so... you would get a 911 rear caliper pad kit for $35.00 and two rear 914 springs, performa a little Pop-Rivet magic and you're good to go there. We have new compensating lines as well.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
  1. Spacer Ring
    By merbesfield in forum Technical Info
    Last Post: 11-10-2013, 03:21 AM
  2. Spacer and o-ring
    By 71-911T in forum Technical Info
    Last Post: 09-19-2012, 10:32 AM
  3. Steering wheel spacer ??
    By Greg D. in forum Technical Info
    Last Post: 05-23-2012, 06:51 AM
  4. 72 Wheel Spacer Sizes
    By gsjohnson in forum Technical Info
    Last Post: 12-08-2009, 12:40 PM
