Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: paint code help please
    Hi folks,wondering if someone could help with a paint code for 73 gemini blue from PPG they don't seem to have one showing.Thanks in advance
    Marty
    Lightbulb
    Marty,
    PPG need to cross-reference it through Glasurit ......
    Look for 1970 #335
    http://members.rennlist.com/tweedt/glasurit.htm
    Hope this helps,
    Cheers
    I recently got '70 tangerine from PPG, and they only had it listed under the german name, and the 3 digit code was preceded by POR. It took a little searching before we hit on the right combination of letters and numbers. So if Gemini Blue Metallic is 330, search POR330. They may not have all the special order colors on the books, though.
    Mike
    Mike Caterino
    1970 T targa
    Santa Barbara, CA
    restoration blog: mk911.blogspot.com
    Dec 2003
    West Los Angeles
    I see here:
    http://www.elferhelfer.com/farben.htm
    They show #330, but I swear my Gemini '73 was stamped 335. In any case, I had the color custom-mixed from sampling the hood latch panel.
    techweenie.com
    Senior Member Milou's Avatar
    Mar 2006
    Geneva
    Gemini Blue!
    Both numbers are correct I think, Gemini blue had paint code #330 in 1972 and paint code #335 for the following year 1973
    Milou / Registry #884
    www.ecurielyford.com
    Peter Kane
    '72 911S Targa
    Jul 2009
    Vancouver, BC
    Gemini B.
    Does anyone know someone with a 1970 model originally painted Gemini Blue? Several reference guides seem to indicate that this colour was first available in 1971.
    The colour guides do show it as a 1970 however.
    Thanks for all the help so far.the problem is I know the code but my painter who uses PPG cant find the formula through them and if I have gone this far I dont want to screw with the true colour. what to do?
    Marty
    Oct 2008
    Burford, ON, Canada
    Herman Maire on Pelican painted a car in Gemini with PPG. Perhaps he can help.
    http://forums.pelicanparts.com/porsc...her-paint.html
    I don't have a 1970 specifically in Gemini, but do have a few possibles that are called metallic blue. I only have one 1971 specifically in Gemini.
    I did not find the PPG site to be very helpful. I did find this:
    http://www.carpaintonline.com/paints...64&OEMCode=335
    The third item on the list indicates that the PPG code that matches your code 335 is 2373. Hope this helps.
    Peter Kane
    '72 911S Targa
  1. Replies: 9
    Last Post: 01-06-2017, 01:44 AM
  2. Wanted: paint code plate w/ Conda green code
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2009, 07:33 PM
  3. Name that paint code..
    By budge96 in forum General Info
    Last Post: 08-08-2009, 10:55 AM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
  5. Paint Code help
    By Paul in forum Technical Info
    Last Post: 06-20-2002, 03:42 PM
